Getting error when using: 'dijit/form/ComboBox' and 'dojo/dom-construct'
2258
01-23-2018 04:30 AM
WarleyMendes
Hi Guys,
I'm trying to insert values in a ComboBox using domConstruct.create.
When I select a city (cbxMunicipio) the regins ComboBox (cbxBairro) needs to be filled.
But I'm getting error in the follow line:
domConstruct.create("option", { value: "111", innerHTML: "test" }, cbxB);
My Code:
Widget.html:
<div>
Municipio:
<select data-dojo-attach-point="cbxMunicipio" data-dojo-type="dijit/form/ComboBox"
   style="width:200px;" value="Selecione...">
   <option value="4000">Vitoria</option>
   <option value="3500">Serra</option>
</select>
Bairro:
<select data-dojo-attach-point="cbxBairro" data-dojo-type="dijit/form/ComboBox" style="width:200px;">
</select>
</div>
Widget.js
define([
'dojo/_base/declare',
'jimu/BaseWidget',
'dijit/_WidgetsInTemplateMixin',
'dijit/form/ComboBox',
'dojo/_base/lang',
'dojo/dom-construct',
'dojo/dom',
'dojo/on',
'dojo/domReady!'
function(
declare,
BaseWidget,
_WidgetsInTemplateMixin,
ComboBox,
lang,
domConstruct,
dom,
on
return declare([BaseWidget, _WidgetsInTemplateMixin], {
baseClass: 'jimu-widget-customwidget',
startup: function() {
   this.inherited(arguments);
   console.log('startup');
onOpen: function(){
   on(this.cbxMunicipio, "change", lang.hitch(this, this._getMunicipioChange));
_getMunicipioChange: function(evt){
   var cbxB = domConstruct.create(this.cbxBairro);
   console.log('OK....');
Someone have any idea what I'm doing wrong?
Warley
WarleyMendes
Hi Ken Buja, thanks for you replay.
I Change my code and it is working fine now.
define([
 'jimu/BaseWidget',
 'dojo/store/Memory',
 'dojo/_base/lang',
 'dojo/dom',
 'dojo/on',
 'dojo/domReady!'
 function(
 declare,
 BaseWidget,
 ComboBox,
 Memory,
 lang,
 dom,
 on
 onOpen: function(){
    var values = [];
    values.push(
       {id: "111", value: "111", name: "test1"},
       {id: "112", value: "112", name: "test2"},
       {id: "113", value: "113", name: "test3"}
    var dataItems = {
       identifier: "value",
       label: "name",
       items: values
    var store = new Memory({
       data: dataItems
    console.log(dataItems);
    console.log(store);
    this.cbxBairro.set("store", store);
The original link:
https://community.esri.com/message/558271?commentID=558271#comment-558271
Thank you guys,
Warley
RobertScheitlin__GISP
Warley,
  So this is the code I use for that:
   var option = {
     value: "111",
     label: "test"
   this.cbxBairro.addOption(option);
In your code I am not sure why you were trying to use domConstruct on a already created and valid select element:
WarleyMendes
Hi Robert, thanks for your quick replay.
But I still getting error, because in dijit/form/ComboBox there is no addOptin function, as described on the API Documentation:
API Documentation - The Dojo Toolkit Version 1.10
KenBuja
MVP Esteemed Contributor
The Select dijit has the addOption method
WarleyMendes
define([
 'jimu/BaseWidget',
 'dojo/_base/lang',
 'dojo/dom',
 'dojo/on',
 'dojo/domReady!'
 function(
 declare,
 BaseWidget,
 ComboBox,
 Memory,
 lang,
 dom,
 on
 onOpen: function(){
    var values = [];
    values.push(
    var dataItems = {
       label: "name",
       items: values
       data: dataItems
    console.log(store);
The original link:
Thank you guys,
Warley
