FindTask Custom Widget
1197
06-14-2018 04:44 PM
KellyGreen1
Hello,
Has anyone created a custom widget from scratch that uses the FindTask class?  Or if anyone has some insight on how go about doing this, that would be helpful as well.
RobertScheitlin__GISP
Kelly,
   I am not aware of any shared custom widget that uses the FindTask. As far as insight you need to follow the Sample Code
Create a custom in-panel widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developer...
To get a basic in-panel widget and then add your UI and code that uses the Find Task to the Widgets.js file.
KellyGreen1
Hi Robert,
Thanks for your response and link to the sample code.  I have actually gone through that tutorial before and was just wondering if anyone else had done the legwork.  But it doesn't seem like that is the case...
Kelly
