FindTask Custom Widget: onRowClickHandler Not Firing
1631
02-13-2020 01:43 PM
KellyGreen
Still trying to build a custom widget for WAB with the same functionality as the FindTask class in the Java Script API.  So far, my code searches for an attribute value in a rest service and returns the search results in a table grid.  Next step would be to click on a row in the table grid and zoom to that feature.  I added in the onRowClickHandler code jargon but nothing happens when I click on a row.  Again, I’m a JavaScript super novice so any input would be much appreciated.
Here is my Widget.js code:
define([
  // Specify required modules
  "dojo/_base/declare",
  "jimu/BaseWidget",
  'dijit/_WidgetsInTemplateMixin',
  "esri/tasks/FindTask",
  "esri/tasks/FindParameters",
  "esri/symbols/SimpleFillSymbol",
  "dgrid/OnDemandGrid",
  "dgrid/Selection",
  "dojo/_base/array",
  "esri/symbols/SimpleLineSymbol",
  "esri/graphic",
  "dojo/store/Memory",
  "dojo/_base/Color",
  "dijit/layout/ContentPane",
  "esri/layers/FeatureLayer",
  "dojo/on",
  "esri/lang",
  'dojo/_base/lang',
  "dijit/registry",
  "esri/geometry/Extent",
  "esri/map",
  "esri/tasks/QueryTask",
  "esri/tasks/query"
  function (
    declare,
    BaseWidget,
    _WidgetsInTemplateMixin,
    FindTask,
    FindParameters,
    SimpleFillSymbol,
    Grid,
    Selection,
    arrayUtils,
    SimpleLineSymbol,
    Graphic,
    Memory,
    Color,
    FeatureLayer,
    on,
    esriLang,
    lang,
    registry,
    Extent,
    map,
    QueryTask,
    Query
    var clazz = declare([BaseWidget, _WidgetsInTemplateMixin], {
      baseClass: 'jimu-widget-findtask',
      grid: null,
      postCreate: function () {
        this.grid = new (declare([Grid, Selection]))({
          bufferRows: 5,
          columns: {
            "id": "ID",
            "Parcel_Num": "Parcel ID",
            "Owner1": "Owner 1",
            "Owner2": "Owner 2",
            "Prop_Adrs1": "Property Address",
            "Prop_Adrs2": "City",
            "Lgl_Desc1": "Legal 1",
            "Lgl_Desc2": "Legal 2",
            "Lgl_Desc3": "Legal 3",
            "Lgl_Desc4": "Legal 4",
            "Lgl_Desc5": "Legal 5",
        }, this.searchResultsTable);
        this.grid.startup();
      buttonClickHandler: function () {
        console.log('clicked!', this.searchBox.value);
        var find = new FindTask("https://maps.co.blaine.id.us/server/rest/services/ParcelInfo/MapServer");
        var params = new FindParameters();
        var center, zoom;
        params.returnGeometry = true;
        params.layerIds = [5];
        params.searchFields = ["parcel_num", "owner1"];
        params.outSpatialReference = map.spatialReference
        params.searchText = this.searchBox.value;
        find.execute(params, (results) => {
          console.log('results', results[0]);
          this.showResults(results);
      //This function works with an array of FindResult that the task returns
      showResults: function (results) {
        this.map.graphics.clear();
        var symbol = new SimpleFillSymbol(
          SimpleFillSymbol.STYLE_SOLID,
          new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([50, 194, 204]), 3),
          new Color([255, 255, 255, 0])
        //create array of attributes
        var items = arrayUtils.map(results, (result) => {
          var graphic = new Graphic(result.feature.toJson());
          graphic.setSymbol(symbol);
          this.map.graphics.add(graphic);
          return result.feature.attributes;
        //Create data object to be used in store
        var data = {
          identifier: "FID", //This field needs to have unique values
          label: "RecordNo", //Name field for display. Not pertinent to a grid but may be used elsewhere.
          items: items
        console.log('items', items);
        //Create data store and bind to grid.
        var memStore = new Memory({ data: data }); {
          this.grid.setStore(memStore);
          this.grid.resize();
          console.log('testkgclick!', this.selectedTaxLot);
        onRowClickHandler: function(selectedTaxLot) {
            var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).FID[0];
            var selectedTaxLot = arrayUtils.filter(this, function (graphic) {
              return ((graphic.attributes) && graphic.attributes.FID === clickedTaxLotId);
            if ( selectedTaxLot.length ) {
              this.map.setExtent(selectedTaxLot[0].geometry.getExtent(), true);
    return clazz;
Here is the Widget.html code:
<div>
Parcel Number/Owner Name/Address/Legal Description:
<input type="text" data-dojo-attach-point="searchBox" size="40" />
<button class="favorite styled" type="button" data-dojo-attach-event="click:buttonClickHandler">
Search
</button>
<div data-dojo-attach-point="resultsArea"></div>
<br>
<div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom', splitter:'true'"
style="height:650px;font-size:10pt;">
<div data-dojo-attach-point="searchResultsTable" class="resultsGrid"></div>
</div>
</div>
RobertScheitlin__GISP
Kelly,
  I do not see anywhere where you are wiring the onRowClcikHander to your grid.
this.grid.on("dgrid-select", onRowClickHandler);
KenBuja
MVP Esteemed Contributor
You do have a problem with your require modules not matching your function arguments. You left out an argument for ContentPane between Color and FeatureLayer.
