Feature Layer from Feature Collection applyEdits don't work
6943
20
04-20-2017 03:45 AM
ZdeněkSoldán
Hello,
In a widget I create a new Feature Layer from Feature Collection. From web service I want to add features to this Feature Layer. When I fire applyEdits() function to add the features everything goes well without any error message. But the Feature Layer is still empty. I tried to add edits-complete event and it also fired after complete adding features, so everything seems to be good but the Feature Layer is still empty.
My code is almost the same as this sample code Feature collection | ArcGIS API for JavaScript 3.20
But I don't know where could be the problem because the whole code works.
Have anyone an idea?
Thanks for any help.
ZdeněkSoldán
Robert,
I found what was wrong. The problem was really in the response from web service. Our projection must have minus sign before number and x and y coords are swapped in web service.
Now everything works.
Thank you for your time.
RobertScheitlin__GISP
Zdeněk,
   You would need to share your code. I do this all the time and have had FeatureLayer FeatureCollection working in my eSearch widget for a long time now.
ZdeněkSoldán
Robert,
Here is my code:
startup: function() {
        this.inherited(arguments);
        var map = this.map;
        var featureLayer;
        //create a feature collection
        var featureCollection = {
           "layerDefinition": null,
           "featureSet": {
              "features": [],
              "geometryType": "esriGeometryPoint"
        featureCollection.layerDefinition = {
           "geometryType": "esriGeometryPoint",
           "objectIdField": "ObjectID",
           "drawingInfo": {
            "renderer": {
              "type": "simple",
              "symbol": {
                "type": "esriPMS",
                "url": "images/carElt.png",
                "contentType": "image/png",
                "width": 15,
                "height": 15
           "fields": [{
              "name": "ObjectID",
              "alias": "ObjectID",
              "type": "esriFieldTypeOID"
              "name": "car_spz",
              "alias": "Vozidlo (SPZ)",
              "type": "esriFieldTypeString"
              "name": "Locality",
              "alias": "Lokalita",
              "name": "Age",
              "alias": "Stáří",
        //define a popup template
        var popupTemplate = new PopupTemplate({
           title: "{Vozidlo (SPZ)}",
           //description: "{description}"
        //create a feature layer based on the feature collection
        featureLayer = new FeatureLayer(featureCollection, {
           infoTemplate: popupTemplate
        //associate the features with the popup on click
        featureLayer.on("click", function(evt) {
          map.infoWindow.setFeatures([evt.graphic]);
        map.on("layers-add-result", function(results) {
          requestCar();
        map.addLayers([featureLayer]);
        function requestCar() {
          var requestHandle = esriRequest({
            url: "http://server.domain.cz/ws/?cmd=getrealtimevehiclelist&auser=carposition&apass=0dotlE&outproj=JTSK&r...",
            handleAs: "json"
          requestHandle.then(requestSucceeded, requestFailed);
        function requestSucceeded(response, io) {
        //loop through the items and add to the feature layer
        var features = [];
        array.forEach(response.response.resultitems, function(item) {
          //console.log(item)
          var attr = {};
          attr["car_spz"] = item.fullname;
          attr["Locality"] = item.locality;
          attr["Age"] = item.age;
          //console.log(attr)
          var geometry = new Point({"x":item.position.x,"y":item.position.y,"spatialReference":{"wkid":5514}});
          //console.log(geometry)
          var graphic = new Graphic(geometry);
          graphic.setAttributes(attr);
          features.push(graphic);
        console.log(features)
        featureLayer.applyEdits(features, null, null, function (add){
          array.forEach(add, function (a){
            console.log("success")
            console.log(a.status)
        }, function (error){
          console.log("error")
          console.log(error)
      function requestFailed(error) {
        console.log('failed');
the features object is after forEach loop successfully filled. ApplyEdits goes through a function not error function but the feature layer remains empty.
Zdeněk,
   If you are using an esri basemap then you will need to re-project your graphics to 102100 as your 5514 data will not work properly since this is a featurecollection and does not automatically re-project your data.
ZdeněkSoldán
Robert,
I am not using an esri basemap. My basemap has the same projection as created points.
So if you where to add this code:
console.info(this.map.spatialReference.wkid);
it would return 5514? Can you check that for me?
ZdeněkSoldán
It returned 102067 which is the second wkid for the same projection. For sure I changed the wkid of points to the same 102067. But the feature layer is still empty.
And your sure the data coming from
is in WKID 102067 or 5514 and not something like 4326?
ZdeněkSoldán
Yes, I am sure.
But maybe I found where is the problem. The feature layer I created has spatialReferece 4326. But in the documentation FeatureLayer | API Reference | ArcGIS API for JavaScript 3.20 I didn't find if it's possible to change spatialReference for feature layer made from featureCollection. I tried to add the code
"spatialReference":[{
"wkid":102067
to the layerDefiniton part but the spatialReference of the feature layer is still 4326.
Well the spatialReference is not expecting an array.
"wkid":102067
But I don't think you can specify the spatialReference in the layerDefinition anyway.
I don't see how the layer is getting a wkid of 4326 since I don't see that in your code anywhere and the geometry you are adding has a spatialReference defined.
