eSearch Widget
3006
02-03-2016 08:39 AM
RudoDuncan
Robert Scheitlin, GISP
Can I put this code in my config.json file so that my IncDate field would return the year only? Current it's 20160203.
"name": "IncDate",
            "alias": "IncDate",
            "sqltext": "IncDate = Left('[value]',4)"
I am trying to change:
alias": "{IncNum}",
            "disablelinksifnull": true,
            "disableinpopup": false,
            "popuptype": "text",
            "content": "http://phqrpt01/ReportServer/Pages/ReportViewer.aspx?%2fPatrol%2fCAD%2fCallsForService&rs:Command=Render&rc:Parameters=false&Year=2016&IncNum={IncNum}",
To this:
So that any year that is available, a report would pop up when the link is clicked.
%2fPatrol%2fCAD%2fCallsForService&rs:Command=Render&rc:Parameters=false&Year={IncDate)&IncNum={IncNum}",
RobertScheitlin__GISP
Rudo,
   Sure I think this thread will get you going on this. You may have to read some of the earlier traffic between Kevin and I to get the context though.
https://community.esri.com/docs/DOC-1731#comment-20232
Rudo,
No the SQL query text will not manipulate the returned vales of a field like that. The SQL text will only affect which features are returned and not the attribute values returned.
RudoDuncan
Do you know of a method to do so? Would have an idea of the .js or .json that would do something like that?
Rudo,
