eSearch Widget results and pop up window
1848
02-26-2016 10:14 AM
RudoDuncan
Robert Scheitlin, GISP
Hello again Robert,
My Inc Date & Time field in the results and pop up window does not display the time (only the Date). However, in the attribute table both date and time is displayed. Is there a fix so that my users can easily see both date and time in the result box & pop up window?
RobertScheitlin__GISP
Rudo,
   All you have to do is select the desired date field format in the fields table in the widgets configuration UI.
Rudo,
