eSearch Widget Question
4506
03-16-2015 02:05 PM
LukeMiles1
Good afternoon,
I recently stumbled across a possible issue with the eSearch Widget. I noticed that any time I execute a search and have the results added as an operational layer, it's not automatically adding the result into the Attribute Table. Forgive me if this is just a simple fix, but I just can't seem to get it to work. I'm using WAB (Developer Edition 1.0). Any help would be greatly appreciated.
Thanks in advance.
RobertScheitlin__GISP
Luke,
   Thanks for pointing this issue out. I will have a look and see If I can get it fixed for the next version.
Luke,
LukeMiles1
Thanks for the help, Robert. Glad to know I wasn't just missing something simple.
Luke,
   Just an update on this issue. So far in my testing it is looking like a Attribbute Table widget issue. I will keep digging and confirm this before I stop looking though.
LukeMiles1
Ok, thanks for all of your help. If it is an attribute widget issue, what would be the next step in fixing it? Edit the widget code?
It would involve producing a test case that uses esri sample data and NO custom widget like eSearch and reporting this to esri tech support as the Attribute Table Widget is an OTB esri widget.
