eSearch Widget Graphic Icon PopUp
2576
03-17-2016 08:25 AM
MarleneBrunot1
For the eSearch Widget, is there a simple way to display an infowindow inside of the WAB when the graphic icon from the results panel is clicked, similar to the Calhoun County Parcel Viewer example:
ArcGIS Web Application
I'm not looking to generate a complicated report. Just want it to display a larger graphic image when the user clicks on the graphic icon from the results panel. Right now the hyperlinked image opens in a new window. I would like it to display inside of WAB.
Please help. Thank you!
RobertScheitlin__GISP
Marlene,
  My site uses a completely custom MobilePopup.js file that is a responsive container dijit that I add html content to. There is nothing otb that allows for this. My site also uses a custom asp.net restful web service to get the house image and data about the parcel and the report is build using dojo domConstruct to create the html elements in the template html that is displayed in the MobilePopup.
Marlene,
MarleneBrunot1
Ok, thank you for the quick response!
 MARLENE BRUNOTGeographic InformationSystems (GIS) [email protected]
To: Marlene Brunot <[email protected]>
Sent: Thursday, March 17, 2016 1:30 PM
Subject: Re: - eSearch Widget Graphic Icon PopUp
#yiv7679034326 * #yiv7679034326 a #yiv7679034326 body {font-family:Helvetica, Arial, sans-serif;}#yiv7679034326 #yiv7679034326 h1, #yiv7679034326 h2, #yiv7679034326 h3, #yiv7679034326 h4, #yiv7679034326 h5, #yiv7679034326 h6, #yiv7679034326 p, #yiv7679034326 hr {}#yiv7679034326 .yiv7679034326button td {}
GeoNet
reply from Robert Scheitlin, GISP in Web AppBuilder Custom Widgets - View the full discussionMarlene,   My site uses a completely custom MobilePopup.js file that is a responsive container dijit that I add html content to. There is nothing otb that allows for this. My site also uses a custom asp.net restful web service to get the house image and data about the parcel and the report is build using dojo domConstruct to create the html elements in the template html that is displayed in the MobilePopup.
Reply to this message by replying to this email, or go to the message on GeoNet
Start a new discussion in Web AppBuilder Custom Widgets by email or at GeoNet
Following eSearch Widget Graphic Icon PopUp in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences |
