eSearch widget customization
9317
20
03-25-2016 08:20 AM
ZhujingXia
Robert,
I'd like to customize the Esearch little bit. I'd like to get a report for the result of the search( may be a new window of HTML page to list the result attribute info). I created a 'report' button next to the 'clear' button on the result tab. if user click on the 'report' button a new window will open to show all the attribute info. I could get the result data from
this.currentFeatures.attributes.ADDRESS;
this.currentFeatures.attributes.Parcel_ID;
I have to list all the field names individually, I have a long list of the field name. Is there a easy way get the field name and attribute info all together within a for loop?
RobertScheitlin__GISP
Zhujing,
Just use this.currentLayerAdded
ZhujingXia
worked
ZhujingXia
Robert,
I used the ESearch to create buffer around the parcel. The buffer will add into the map as a operation layer. When I use the print widget to print out, the buffer in the legend on printout map shows as 'Override 1'. Is there a way to change it and show the correct legend on the printout?
No this seems to be a ArcGIS Server issue.
ZhujingXia
Robert,
In this eSearch Widget, if I go to the By shape Tab. The enable multi-part graphics is unchecked by default. How could I make it checked by default?
Zhujing
Zhujing,
Edit the Widget.html:
<div data-dojo-type="jimu/dijit/CheckBox" data-dojo-attach-point="cbxMultiGraphic" data-dojo-props="checked: true"></div>
ZhujingXia
Robert,
I added in  data-dojo-props="checked: true", but it dose not work.
Zhujing
Zhujing,
  Ahh, I forgot I already added a configuration option for this. Click on the "Edit Graphical Search Options" at the bottom of the main widget settings page and you will see the option there.
ZhujingXia
Robert,
Worked. Thanks
ZhujingXia
Robert,
Is that possible to remove the attribute table fro this widget?
Zhujing
