eSearch Widget: add a button
1324
11-05-2020 10:47 AM
JamesCrandall
MVP Alum
Robert / All,
I dislike having to butcher this excellent widget but I have a request to move an existing widget click-button onto the actual eSearch widget panel's results tab.  Any suggestions on how to best/properly fit the "Download Data" button as seen here?
It's hiding the results counter and that particular div height doesn't allow it to fit well.  I'd rather not go an hammer away at this and figure best to check first.  (I'm terrible with placement/styling of html elements)
RobertScheitlin__GISP
James,
   Give this a go:
style.css
.widget-esearch .esearch-result-download-button{
  position: absolute;
  right: 24px;
  height: 6px;
  line-height: 0;
  font-size: 8pt;
  padding: 8px;
Widget.html (line 6)
    <div class="search-tab-node-hidden" data-dojo-attach-point="tabNode4" style="overflow: hidden;">
      <div data-dojo-attach-point="progressbar"></div>
      <div data-dojo-attach-point="divResultMessage" class="esearch-noResults"></div>
      <div class="popup-menu-button esearch-result-action-button" data-dojo-attach-event="click:_onBtnMenuClicked" data-dojo-attach-point="divOptions" title="${nls.resultactions}" style="display:none;"></div>
      <div class="esearch-result-download-button search-btn" data-dojo-attach-point="divDownload" title="Download Data" style="display:none;">Download Data</div>
      <div data-dojo-attach-point="listDiv"></div>
      <label data-dojo-attach-point="divSum" class="esearch-sum" style="display:none;"></label>
    </div>
Widget.js
//Search for
html.setStyle(this.divOptions, 'display', 'block');
//and add this line after it
html.setStyle(this.divDownload, 'display', 'block');
//search for this
html.setStyle(this.divOptions, 'display', 'none');
html.setStyle(this.divDownload, 'display', 'none');
The click event is on you.
James,
   Give this a go:
style.css
  position: absolute;
  right: 24px;
  height: 6px;
  line-height: 0;
  font-size: 8pt;
  padding: 8px;
    </div>
Widget.js
//Search for
//search for this
JamesCrandall
MVP Alum
I got it to work just fine, much appreciated.
I really need to update my eSearch, no idea what version I'm on.  So hard to keep up with so many apps, I'm even way behind on WABDev version.
Thanks again for the assist.
