Enhanced Search: Search Link(s) encoding?
1218
01-28-2020 10:08 AM
JamesCrandall
WAB Developer 2.7
Enhanced Search 2.7
Just now realizing that the Search Link(s) property of the enhanced search widget is not encoding the url value.  Per this image, the {NAME} value would be "STA-5/6" and the resulting clickable link is https://oursite.com/#/sta/STA-5/6 which fails to navigate.
Since the resulting url link in the search widget panel would be literal and not encoded, it does not properly navigate to the destination.  The same url link displayed in the popup when hovering over the selected feature is correctly encoded as,
https://oursite.com/#/sta/STA-5%2F6
RobertScheitlin__GISP
James,
  In the widget.js replace the current _substitute function with this one:
      _substitute: function (string, Attribs, currentLayer, urlEncode) {
        var lfields = this._getFieldsfromLink(string);
        for (var lf = 0; lf < lfields.length; lf++) {
          if (Attribs[lfields[lf]]) {
            var fld = this._getField(currentLayer, lfields[lf]);
            var val;
            if (fld.type === "esriFieldTypeString") {
              if(urlEncode){
                val = encodeURIComponent(lang.trim(Attribs[lfields[lf]]));
              }else{
                val = lang.trim(Attribs[lfields[lf]]);
              string = string.replace(new RegExp('{' + lang.trim(lfields[lf]) + '}', 'g'), val);
            } else {
              if(urlEncode){
                val = encodeURIComponent(Attribs[lfields[lf]]);
              }else{
                val = Attribs[lfields[lf]];
        return string;
And then search the widget.js for "this._substitute".
OLD CODE
            if (linkFieldNull) {
              link = "";
            } else {
              link = this._substitute(qLinks[a].content, featureAttributes, results);
            var sub = this._substitute(qLinks[a].alias, featureAttributes, results);
            alias = (sub) ? sub : qLinks[a].alias;
            linkicon = this._substitute((qLinks[a].icon || this.folderUrl + 'images/w_link.png'), featureAttributes, results);‍‍‍‍‍‍‍‍
and add the fourth parameter like this:
NEW CODE
              link = "";
            } else {
              link = this._substitute(qLinks[a].content, featureAttributes, results, true);
            var sub = this._substitute(qLinks[a].alias, featureAttributes, results, false);
            linkicon = this._substitute((qLinks[a].icon || this.folderUrl + 'images/w_link.png'), featureAttributes, results, false);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
James,
  Correct there is nothing in the widget code that tells it to encode the value of the field. I can fix this for the latest version of eSearch widget.
JamesCrandall
Thanks Robert!  Is there any patch I can apply quickly?  We have a production app that is experiencing this issue.
James,
            var val;
              if(urlEncode){
              }else{
            } else {
              if(urlEncode){
              }else{
        return string;
OLD CODE
              link = "";
            } else {
NEW CODE
              link = "";
            } else {
JamesCrandall
Big save there Robert. Much appreciated!
...Off to emergency change control I go.
