Enhanced Search - Changing a word in the widget
2461
05-18-2016 06:48 AM
Nicole_Ueberschär
In the widget it says "Search alias" but I don't think that my user will know what that means. So I wanted to change it to "Search by criteria". I looked through all the eSearch files and found one "Search alias" in strings.js. I changed it to "Search by criteria" but it does not change in the widget. Where else can I find and change it?!
Tags (1)
RobertScheitlin__GISP
Nicole,
  When you change searchType: "Search alias", in the strigs.js file that is all you should have to do. Now it is a question of did you clear your browsers cache and did you make the strings.js change in your apps copy of the strings.js or only in the stemapps copy of strings.js?
