Hey all, hope things are well. I've been working on a widget to allow for editing tables in the Web App Builder via the Attribute Table widget, and I've got a promising prototype working in the repo below. I hope to continue improving this tool in the future, but it's a good start so far. Testing on versions above 2.5 would be appreciated.
Note that this widget requires the use of the LocalLayer widget to add Table sublayers in FeatureServices to your map as Feature Layers. More information about this widget below.
https://community.esri.com/thread/119548-locallayerwidget-and-accessifizrwidget
Look forward to your feedback!
Hey Adam,
I have two questions; One, it seems like you have to have the feature associated table as a service as well. Does that mean bringing dbf as a table service? Two, this then will have to be a customized Web AppBuilder app. You mention GitHub. It will not be an out of the box Web AppBuilder app, right?
Thank you.
Abi
Has anyone implemented this widget with 10.6.1? Any issues?
I'm looking for a widget exactly as this is describe. I downloaded it from git and installed it on my instance of WebAppBuilder and it looks good, except I can't get it to add a new record (which is the function that I really need the most). From the code it looks like maybe you hadn't gotten to this yet. I'm a complete novice on JavaScript - so I have high hopes that this will work out for me. Is there a newer version that supports add - or am I missing something with this 2.5 version? Thanks!
var addFeature = esriRequest({
url: addUrl,
content: {
f: "json"
handleAs: "json",
content: {
adds: '[{"id":222,"adds":[],"updates":[],"deletes":[]}]',
f: "json"
Hi Don,
Did you happen to make any progress with finding a means to add a new record? I am also a JavaScript novice but need to figure out how to add new related records, instead of just being able to edit existing records.
Anna
Hi Anna - I did not make any progress on this widget. I ended up creating some python toolbox tools to help users add records and related records to our database. This has turned out to be very difficult and complicated to develop, and not a very nice user interface. Other than than it works great. These tools only run in the ArcGIS Pro client - we would have like to have provided a web interface.
Thanks for the reply Don - yet it's proving to be quite complicated!
Hello, I'm trying to implement this widget but keep receiving the error "Table is either not a table or not editable". I added the layer via the LocalLayer widget and the layer is editable so I do not understand why the widget will not read this layer.
I am also very new to Java so there could be some basic underlying issues. For instance, I don't understand if this opening function is necessary for me to fill out:
Both times when I have used my server/domain and when I have left this enactive I have received the same error message in WAB saying the table is not editable.
Are there other configurations I am missing in the EditTable widget's code?
Thank you
I didn't have to change any code to get it to work for me (except the add new record does not work as advertised) so you shouldn't have to worry about the comments in the onOpen function. It was only a couple of weeks ago but I can't remember if I had to do any tricks to get it to work. Do you have at least one spatial layer in your feature service? I think I had to add a dummy spatial layer to get it to work. This is from the readme file: Note that at least one spatial layer is currently required to be added to your map via the LocalLayer widget for the map to load.
