Edit widget - how to set attribute field value programatically
4042
12-22-2015 02:56 PM
TobiasFimpel1
When adding a feature I want to set an attribute field value programatically instead of filling it out manually. I cannot figure out where in the Edit widget's Widget.js file I could do this. Has anyone an example or suggestions of how to do this with the WAB (v1.3) Edit widget?
RobertScheitlin__GISP
Tobias,
   Sure look at this thread where I answer that:
Re: Edit Widget - time not visible when DateTime field has time enabled
