Edit time on Edit widget
1008
09-15-2020 12:44 AM
VictorTey
Hi, using build in WAB on ArcGIS Enterprise 10.7.1, I have a date field where I can see the time. However using the edit widget, i can only set the date field.
I saw a post Edit Widget - time not visible when DateTime field has time enabled  that suggest fixing it on _convertConfiguredLayerInfos however that code never gets called. It always goes to this._getDefaultLayerInfos().  And I don't think we have exactly the same issue  can someone please advise
I am expecting to see which I currently don't.
Robert Scheitlin, GISP‌ hopefully you can help
RobertScheitlin__GISP
Victor,
   You will only get to that area of the code if you choose "Custom settings" in the widgets settings dialog.
