disableKeyboardNavigation() -- where to place it?
3958
09-30-2015 10:50 AM
RyanStrain
I'm trying to disable keyboard navigation and for the life of me can't find where to place it for it to actually work. I've tried numerous places within the MapManager.js, a few places within LayoutManager.js and a few other shots in the dark to no avail. After each attempt the number key pad will still pan the map. Any ideas? Thanks.
RobertScheitlin__GISP
Ryan,
  Here is what works for me. In the MapManager.js add line 44.
_show2DWebMap: function(appConfig) {
        //should use appConfig instead of this.appConfig, because appConfig is new.
        // if (appConfig.portalUrl) {
        //  var url = portalUrlUtils.getStandardPortalUrl(appConfig.portalUrl);
        //  agolUtils.arcgisUrl = url + "/sharing/content/items/";
        if(!appConfig.map.mapOptions){
          appConfig.map.mapOptions = {};
        var mapOptions = this._processMapOptions(appConfig.map.mapOptions) || {};
        mapOptions.isZoomSlider = false;
        var webMapPortalUrl = appConfig.map.portalUrl;
        var webMapItemId = appConfig.map.itemId;
        var webMapOptions = {
          mapOptions: mapOptions,
          bingMapsKey: appConfig.bingMapsKey,
          usePopupManager: true
        var mapDeferred = jimuUtils.createWebMap(webMapPortalUrl, webMapItemId,
          this.mapDivId, webMapOptions);
        mapDeferred.then(lang.hitch(this, function(response) {
          var map = response.map;
          //hide the default zoom slider
          map.hideZoomSlider();
          // set default size of infoWindow.
          map.infoWindow.resize(270, 316);
          //var extent;
          map.itemId = appConfig.map.itemId;
          map.itemInfo = response.itemInfo;
          map.webMapResponse = response;
          // enable snapping
          var options = {
            snapKey: keys.copyKey
          map.enableSnapping(options);
          html.setStyle(map.root, 'zIndex', 0);
          map.disableKeyboardNavigation();
          this._publishMapEvent(map);
        }), lang.hitch(this, function() {
          if (this.loading) {
            this.loading.destroy();
          topic.publish('mapCreatedFailed');
Ryan,
          //var extent;
          // enable snapping
          var options = {
          if (this.loading) {
RyanStrain
That does work...in WAB 1.2. Guess I need to upgrade at some point. In 1.1 it doesn't have any effect. Thanks Robert for shedding some light on a difference between the two versions.
