Directions widget, multiple preset stops?
2208
03-26-2018 01:10 PM
RobertLackage
Is it possible to add more preset stops then just the start and end points in the directions widget? I'd like to have preset directions for multiple points.
RobertScheitlin__GISP
Robert,
  In the Widget.js file make this change to the _onDirectionsActivate function:
      _onDirectionsActivate: function () {
        if (this.config.defaultLocations &&
          this.config.defaultLocations.length && this.config.defaultLocations.length > 0 &&
          false === this._isInitPresetStopsFlag) {
          this._isInitPresetStopsFlag = true;
          this._dijitDirections.addStops(this.config.defaultLocations);
          this._dijitDirections.addStop();
Robert,
   are you asking for the directions widget to open with more then the 2 default stops? If so how many?
RobertLackage
Yes, I'd like 6 default stops to be preset.
Robert,
RobertLackage
Thanks Robert! Your eSearch is the best btw.
