Deploying a web mapping application created using WebApp Builder in AGOL
9334
22
11-17-2017 08:00 PM
JanakiGattu1
Deploying a web mapping application created using WebApp Builder in AGOL...I have downloaded the app from AGOL and uzipped it to access...But it is throwing me an Error as shown below...
JanakiGattu1
Hi Robert,
Could you send me the Json file on my mail address.
[email protected]
RobertScheitlin__GISP
Janaki,
   The last reply I made has the config attached. You will not see attachments inside your inbox on GeoNet. You have to actually click on the message to open it and then you will see the attachment.
JanakiGattu1
Hi Robert,
I am not able to get your config.json file.
Janaki,
   I am not sure why as I see the attachment on my reply. I do not have access to my email right now so I can not send you the file by email.
JanakiGattu1
Hi Robert,
Thank you for the update.
Just copy the entire .json code here, I will replace the old .json code with your code and will check...Hope this works well.
  "theme": {
    "name": "FoldableTheme",
    "styles": ["red", "default", "black", "blue", "cyan", "green", "purple", "yellow"],
    "version": "2.6",
    "sharedTheme": {
      "isPortalSupport": true,
      "useHeader": false,
      "useLogo": false
  "portalUrl": "http://esrit3g.maps.arcgis.com",
  "appId": "",
  "authorizedCrossOriginDomains": [],
  "title": "Spatial Decision Support System for Urban Construction",
  "subtitle": "",
  "keepAppState": true,
  "logo": "http://esrit3g.maps.arcgis.com/sharing/rest/content/items/23868512670d4516a989c52b834a159c/resources...",
  "geometryService": "https://utility.arcgisonline.com/arcgis/rest/services/Geometry/GeometryServer",
  "links": [],
  "widgetOnScreen": {
    "widgets": [{
      "uri": "themes/FoldableTheme/widgets/HeaderController/Widget",
      "position": {
        "left": 0,
        "top": 0,
        "right": 0,
        "height": 40,
        "relativeTo": "browser"
      "version": "2.6",
      "id": "themes_FoldableTheme_widgets_HeaderController_Widget_1",
      "name": "HeaderController"
      "uri": "widgets/Scalebar/Widget",
      "position": {
        "left": 7,
        "bottom": 25,
        "relativeTo": "map"
      "version": "2.6",
      "id": "widgets_Scalebar_Widget_2",
      "name": "Scalebar"
      "uri": "widgets/Search/Widget",
      "position": {
        "left": 55,
        "top": 5,
        "relativeTo": "map"
      "version": "2.6",
      "id": "widgets_Search_Widget_3",
      "name": "Search"
      "uri": "widgets/Coordinate/Widget",
      "position": {
        "left": 7,
        "bottom": 5,
        "relativeTo": "map"
      "version": "2.6",
      "id": "widgets_Coordinate_Widget_4",
      "name": "Coordinate"
      "position": {
        "left": 55,
        "top": 45,
        "relativeTo": "map"
      "placeholderIndex": 1,
      "id": "_5",
      "name": "Print",
      "version": "2.6",
      "closeable": true,
      "uri": "widgets/Print/Widget",
      "config": {
        "serviceURL": "https://utility.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%...",
        "defaultTitle": "Spatial Decision Support System for Urban Construction",
        "defaultAuthor": "@Nandini",
        "defaultCopyright": "@Nandini",
        "defaultFormat": "PDF",
        "defaultLayout": "MAP_ONLY"
      "position": {
        "left": 105,
        "top": 45,
        "relativeTo": "map"
      "id": "_6",
      "name": "Query",
      "version": "2.6",
      "closeable": true,
      "uri": "widgets/Query/Widget",
      "config": {
        "hideLayersAfterWidgetClosed": true,
        "labelTasks": "Query Filter Task",
        "labelResults": "Query Filter Result",
        "queries": [{
          "url": "",
          "name": "Urban Construction",
          "icon": "",
          "filter": {
            "logicalOperator": "AND",
            "parts": [{
              "logicalOperator": "OR",
              "parts": [{
                "fieldObj": {
                  "name": "Wind_Speed",
                  "label": "Wind_Speed",
                  "shortType": "number",
                  "type": "esriFieldTypeDouble"
                "operator": "numberOperatorIsGreaterThan",
                "valueObj": {
                  "isValid": true,
                  "type": "value",
                  "value": 87
                "interactiveObj": {
                  "prompt": "Wind_Speed is greater than",
                  "hint": "",
                  "cascade": "none"
                "caseSensitive": false,
                "expr": "Wind_Speed > 87"
                "fieldObj": {
                  "name": "Earth_Quak",
                  "label": "Earth_Quak",
                  "shortType": "string",
                  "type": "esriFieldTypeString"
                "operator": "stringOperatorIs",
                "valueObj": {
                  "isValid": true,
                  "type": "unique",
                  "value": "Zone_2"
                "interactiveObj": {
                  "prompt": "Earth_Quak is",
                  "hint": "",
                  "cascade": "previous"
                "expr": "Earth_Quak = 'Zone_2'"
                "fieldObj": {
                  "name": "Building_T",
                  "label": "Building_T",
                "valueObj": {
                  "isValid": true,
                  "type": "unique",
                  "value": "Commercial Complex"
                "interactiveObj": {
                  "prompt": "Building_T is",
                  "hint": "",
                "expr": "Building_T = 'Commercial Complex'"
              "expr": "Wind_Speed > 87 OR Earth_Quak = 'Zone_2' OR Building_T = 'Commercial Complex'"
          "showSQL": true,
          "spatialFilter": {
            "currentMapExtent": null,
            "drawing": null,
            "useFeatures": null,
            "fullLayerExtent": null
          "popupInfo": {
            "title": "{FID}",
            "fieldInfos": [{
              "fieldName": "FID",
              "label": "FID",
              "tooltip": "",
              "visible": false,
              "format": {
                "places": 0,
                "digitSeparator": true
              "stringFieldOption": "textbox"
              "fieldName": "Id",
              "label": "Id",
              "tooltip": "",
              "visible": false,
              "format": {
                "places": 0,
              "fieldName": "name",
              "label": "name",
              "tooltip": "",
              "visible": false,
              "format": null,
              "fieldName": "Earth_Quak",
              "tooltip": "",
              "visible": false,
              "format": null,
              "fieldName": "Wind_Speed",
              "tooltip": "",
              "visible": false,
              "format": {
                "places": 2,
              "fieldName": "Flooding_p",
              "label": "Flooding_p",
              "tooltip": "",
              "visible": false,
              "format": null,
              "fieldName": "Building_T",
              "tooltip": "",
              "visible": false,
              "format": null,
              "fieldName": "Area",
              "label": "Area",
              "tooltip": "",
              "visible": false,
              "format": {
                "places": 2,
              "fieldName": "UrbanConstruction",
              "label": "UrbanConstruction",
              "tooltip": "",
              "visible": true,
              "format": null,
              "fieldName": "GlobalID",
              "label": "GlobalID",
              "tooltip": "",
              "visible": false,
              "format": null,
              "fieldName": "CreationDate",
              "label": "CreationDate",
              "tooltip": "",
              "visible": false,
              "format": {
                "dateFormat": "longMonthDayYear"
              "fieldName": "Creator",
              "label": "Creator",
              "tooltip": "",
              "visible": false,
              "format": null,
              "fieldName": "EditDate",
              "label": "EditDate",
              "tooltip": "",
              "visible": false,
              "format": {
              "fieldName": "Editor",
              "label": "Editor",
              "tooltip": "",
              "visible": false,
              "format": null,
            "description": null,
            "showAttachments": false,
            "mediaInfos": [],
            "readFromWebMap": false
          "orderByFields": ["Area ASC"],
          "useLayerSymbol": false,
          "resultsSymbol": {
            "color": [155, 187, 89, 128],
            "outline": {
              "color": [115, 140, 61, 255],
              "width": 1.5,
              "type": "esriSLS",
              "style": "esriSLSSolid",
              "marker": null
            "type": "esriSFS",
            "style": "esriSFSSolid"
          "canModifySymbol": true,
          "keepResultsOnMapAfterCloseWidget": true,
          "enableExport": true,
          "singleResultLayer": false,
          "webMapLayerId": "Urban_Construction_4818"
      "position": {
        "left": 155,
        "top": 45,
        "relativeTo": "map"
      "id": "_7",
      "name": "Share",
      "version": "2.6",
      "closeable": true,
      "uri": "widgets/Share/Widget",
      "config": {
        "socialMedias": {
          "email": true,
          "facebook": true,
          "twitter": true,
          "googlePlus": true
      "position": {
        "left": 205,
        "top": 45,
        "relativeTo": "map"
      "id": "_8",
      "name": "Select",
      "version": "2.6",
      "closeable": true,
      "uri": "widgets/Select/Widget",
      "config": {
        "selectionColor": "#00FFFF",
        "selectionMode": "partial",
        "allowExport": false,
        "geometryTypes": ["EXTENT"]
      "position": {
        "left": 255,
        "top": 45,
        "relativeTo": "map"
      "id": "_9",
      "name": "BasemapGallery",
      "version": "2.6",
      "closeable": true,
      "uri": "widgets/BasemapGallery/Widget",
      "config": {
        "basemapGallery": {
          "mode": 1,
          "basemaps": []
      "uri": "widgets/OverviewMap/Widget",
      "position": {
        "bottom": 0,
        "right": 0,
        "zIndex": 1,
        "relativeTo": "map"
      "version": "2.6",
      "id": "widgets_OverviewMap_Widget_10",
      "name": "OverviewMap"
      "uri": "widgets/HomeButton/Widget",
      "position": {
        "left": 7,
        "top": 75,
        "relativeTo": "map"
      "version": "2.6",
      "id": "widgets_HomeButton_Widget_11",
      "name": "HomeButton"
      "uri": "widgets/MyLocation/Widget",
      "position": {
        "left": 7,
        "top": 110,
        "relativeTo": "map"
      "version": "2.6",
      "id": "widgets_MyLocation_Widget_12",
      "name": "MyLocation"
      "uri": "widgets/AttributeTable/Widget",
      "position": {
      "version": "2.6",
      "id": "widgets_AttributeTable_Widget_13",
      "name": "AttributeTable"
      "uri": "widgets/Splash/Widget",
      "visible": false,
      "position": {
      "version": "2.6",
      "id": "widgets_Splash_Widget_14",
      "name": "Splash"
      "uri": "widgets/ZoomSlider/Widget",
      "position": {
        "top": 5,
        "left": 7,
        "relativeTo": "map"
      "version": "2.6",
      "id": "widgets_ZoomSlider_Widget_15",
      "name": "ZoomSlider"
      "uri": "widgets/ExtentNavigate/Widget",
      "visible": false,
      "position": {
        "top": 150,
        "left": 7,
        "relativeTo": "map"
      "id": "widgets_ExtentNavigate_Widget_16",
      "name": "ExtentNavigate",
      "version": "2.6"
      "uri": "widgets/FullScreen/Widget",
      "visible": false,
      "position": {
        "right": 8,
        "top": 8,
        "relativeTo": "map"
      "version": "2.6",
      "id": "widgets_FullScreen_Widget_17",
      "name": "FullScreen"
    "panel": {
      "uri": "jimu/OnScreenWidgetPanel",
      "position": {
        "relativeTo": "map"
  "map": {
    "3D": false,
    "2D": true,
    "position": {
      "left": 0,
      "top": 40,
      "right": 0,
      "bottom": 0
    "itemId": "12e0b419cc5c4df7a58b9cf5cb661aa7",
    "mapOptions": {},
    "id": "map",
  "widgetPool": {
    "panel": {
      "uri": "themes/FoldableTheme/panels/FoldablePanel/Panel",
      "position": {
        "top": 5,
        "right": 5,
        "bottom": 5,
        "zIndex": 5,
        "relativeTo": "map"
    "widgets": [{
      "uri": "widgets/Legend/Widget",
      "version": "2.6",
      "id": "widgets_Legend_Widget_18",
      "name": "Legend",
      "index": 0
      "uri": "widgets/LayerList/Widget",
      "version": "2.6",
      "id": "widgets_LayerList_Widget_19",
      "name": "LayerList",
      "index": 1
  "mobileLayout": {
    "widgetOnScreen": {
      "widgets": {
        "widgets/Scalebar/Widget": {
          "position": {
            "left": 7,
            "bottom": 40
          "version": "1.4"
        "widgets/Coordinate/Widget": {
          "position": {
            "left": 7,
            "bottom": 17
          "version": "1.4"
  "loadingPage": {
    "backgroundColor": "#508dca",
    "backgroundImage": {
      "visible": false
    "loadingGif": {
      "visible": true,
      "uri": "configs/loading/images/predefined_loading_1.gif",
      "width": 58,
      "height": 29
  "wabVersion": "2.6",
  "_buildInfo": {
    "widgetManifestsMerged": false
  "isWebTier": false,
  "dataSource": {
    "dataSources": {
      "widget~_6~0": {
        "id": "widget~_6~0",
        "type": "Features",
        "label": "Urban Construction",
        "dataSchema": {
          "geometryType": "esriGeometryPolygon",
          "fields": [{
            "name": "FID",
            "type": "esriFieldTypeInteger",
            "actualType": "int",
            "alias": "FID",
            "sqlType": "sqlTypeInteger",
            "nullable": false,
            "editable": false,
            "domain": null,
            "defaultValue": null
            "name": "Id",
            "alias": "Id",
            "nullable": true,
            "editable": true,
            "domain": null,
            "name": "name",
            "type": "esriFieldTypeString",
            "actualType": "nvarchar",
            "alias": "name",
            "sqlType": "sqlTypeNVarchar",
            "length": 50,
            "nullable": true,
            "editable": true,
            "domain": null,
            "alias": "Earth_Quak",
            "length": 50,
            "nullable": true,
            "editable": true,
            "domain": null,
            "type": "esriFieldTypeDouble",
            "actualType": "float",
            "alias": "Wind_Speed",
            "sqlType": "sqlTypeFloat",
            "nullable": true,
            "editable": true,
            "domain": null,
            "name": "Flooding_p",
            "alias": "Flooding_p",
            "length": 50,
            "nullable": true,
            "editable": true,
            "domain": null,
            "alias": "Building_T",
            "length": 50,
            "nullable": true,
            "editable": true,
            "domain": null,
            "name": "Area",
            "alias": "Area",
            "nullable": true,
            "editable": true,
            "domain": null,
            "name": "UrbanConstruction",
            "alias": "UrbanConstruction",
            "sqlType": "sqlTypeOther",
            "length": 50,
            "nullable": true,
            "editable": true,
            "domain": null,
            "name": "GlobalID",
            "type": "esriFieldTypeGlobalID",
            "alias": "GlobalID",
            "length": 38,
            "nullable": false,
            "editable": false,
            "domain": null,
            "defaultValue": "NEWID() WITH VALUES"
            "name": "CreationDate",
            "type": "esriFieldTypeDate",
            "alias": "CreationDate",
            "length": 8,
            "nullable": true,
            "editable": false,
            "domain": null,
            "name": "Creator",
            "alias": "Creator",
            "length": 50,
            "nullable": true,
            "editable": false,
            "domain": null,
            "name": "EditDate",
            "alias": "EditDate",
            "length": 8,
            "nullable": true,
            "editable": false,
            "domain": null,
            "name": "Editor",
            "alias": "Editor",
            "length": 50,
            "nullable": true,
            "editable": false,
            "domain": null,
          "displayField": "",
          "objectIdField": null,
          "typeIdField": ""
    "settings": {}
  "appItemId": "",
  "logoLink": "http://"
JanakiGattu1
Hi Robert,
I copied the code into .json file and removed the earlier code in .json file.
But still the webapp Builder stands as mystery. I am not understanding where is it going wrong.
What web server are you using?
JanakiGattu1
Hi Robert,
I have not deployed the app yet.. I am trying to directly open it local system in a browser...
If it gets opened then I will deploy it on IIS Web server.
MatthewLewis3
Hi Janaki,
You will need to add it to a server such as iis or apache.
You can do this on a local machine by using add features.
