Customized Layer Toggle Not Passing Layer Name
4520
23
03-05-2019 07:42 AM
joerodmey
I've customized Robert's layer toggle widget to look at which layer is currently on and pass this into a popup link that I have. All of my layers follow the same naming scheme of "layername_Main" or "layername_Mezz". The code looks for the underscore symbol as the flag and then applies the main or mezz label to be passed into my link to Survey123.
I have all of this done in MapManager.js in the publishMapEvent function (included below)
Sometimes this works, other times it doesn't. Right now the toggle switches between the layers (from main to mezz) and the link updates properly. But when I toggle back to main, it stays at mezz label even though the layer changes back to main. I want the label to keep up with the toggle.
Any ideas?
_publishMapEvent: function(map) {
        topic.subscribe('toggleChanged', lang.hitch(this, function(visible, layer){
          if(visible && layer.title=='layername_Main'||layer.title=='layername_Mezz'){
            this.SERVICE_ID = layer.title;
		// create node for the tooltip
         var tip = "Click on problem location";
         var tooltip = dojo.create("div", { "class": "tooltip", "innerHTML": tip, "style": "color: red; font-size:22px;width:200px"}, map.container);
          dojo.style(tooltip, "position", "fixed");
          // update the tooltip as the mouse moves over the map
          dojo.connect(map, "onMouseMove", function(evt) {
            var px, py;
            if (evt.clientX || evt.pageY) {
              px = evt.clientX;
              py = evt.clientY;
            } else {
              px = evt.clientX + dojo.body().scrollLeft - dojo.body().clientLeft;
              py = evt.clientY + dojo.body().scrollTop - dojo.body().clientTop;
            // dojo.style(tooltip, "display", "none");
            tooltip.style.display = "none";
            dojo.style(tooltip, { left: (px + 15) + "px", top: (py) + "px" });
            // dojo.style(tooltip, "display", "");
            tooltip.style.display = "";
            // console.log("updated tooltip pos.");
          // hide the tooltip the cursor isn't over the map
          dojo.connect(map, "onMouseOut", function(evt){
        //add this property for debug purpose
        window._viewerMap = map;
        MapUrlParamsHandler.postProcessUrlParams(this.urlParams, map);
        console.timeEnd('Load Map');
        if (this.map) {
          this.map = map;
          this.resetInfoWindow(true);
          console.log('map changed.');
          topic.publish('mapChanged', this.map, this.layerInfosObj);
        } else {
          this.map = map;
          topic.publish('mapLoaded', this.map, this.layerInfosObj);
        require([
          'esri/graphic',
          'esri/symbols/SimpleMarkerSymbol',
          'esri/symbols/SimpleLineSymbol',
          'esri/Color'
		lang.hitch(this, function(Graphic, SimpleMarkerSymbol, SimpleLineSymbol, Color){
          var symbol = new SimpleMarkerSymbol(
         SimpleMarkerSymbol.STYLE_CIRCLE, 0.01,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_CIRCLE,
            new Color([207, 16, 45, 0.9]),
          map.on("click", lang.hitch(this, function(evt){
            var gra = new Graphic(evt.mapPoint, symbol);
            setTimeout(lang.hitch(this, function(){
              var selFeats = map.infoWindow.features;
              if(!selFeats){
                map.graphics.clear();
                map.graphics.add(gra);
				//PopupCenter('http://www.xtf.dk','xtf','900','500');
                map.infoWindow.setContent('<a href="https://survey123.arcgis.com/share/surveycodexyz?center='+ evt.mapPoint.getLatitude().toString() + ','+ evt.mapPoint.getLongitude().toString() + '&field:Floor_Selection=' + this.SERVICE_ID.split('_')[1]+"_Floor " + '" target="_"><font size="4">Click here to submit a service request</font></a>');
				SERVICE_ID: null;
                map.infoWindow.show(evt.mapPoint);
            }), 1000);
joerodmey
is service ID global?
RobertScheitlin__GISP
Sort of. Using this. means that is global in the widgets scope.
joerodmey
Unless for some reason the global aspect isn't working? I'm just throwing things out there.
joerodmey
I duplicated an old app and it worked on new layers perfectly. Don't understand whats the difference. I did have to export each layer in ArcMap with the proper naming
