Customize Legend Widget in WAB 2.6
2457
07-08-2018 09:45 PM
BineetBara
I am having tiled map services as a base map for which legend is not shown in Legend widget. I created images for different scales and toggle the images at zoom in/out. in the legend widget. The image comes above the dynamic feature layer legend , I want it below the dynamic legend shown below.
Legend
Kindly help.
Regards,
Bineet
RobertScheitlin__GISP
Bineet,
   What does your code look like for placing this item?
BineetBara
How can I put custom legend HTML in bottom of dynamic legend HTML?
You do a query for the DOM object and use domContruct place to place the new element in your desired location.
BineetBara
I have tried this but it is not working as expected.
As per my requirement static legend should come after dynamic legend which is dynamically generating.
I have attached widget.js and widget.html with screenshots.
Bineet,
  So your issue is that you have this line in your onOpen function:
this.legend = new Legend(legendParams, html.create("div", {}, this.domNode));
Which means that each time your widget is opened you create a Legend dijit and place it in the widgets main dom node. You do not specify a specific div in the widgets template to place the Legend Dijit in. This is how the OTB widget was developed but you are trying to add your elements at a specific position so you can not use that method.
