Custom Widget Not Showing In Server
2815
12-16-2019 11:53 AM
SamLee1
RobertScheitlin__GISP
Sam,
   It is still showing up as "my widget". This issue is normally that you have not updated the _widgetLabel in the nls/strigs.json or the label in the manifest.json. It can also happen if you have made these changes but need to restart WAB Dev (i.e close the CMD window and relaunch the startup.bat).
Sam,
SamLee1
Thank you. I had to restart WAB Dev.
