Coordinate + Scale widget for WAB Dev 1.3
13520
21
01-27-2016 11:40 AM
BarnabyRockwell
Back in February 2015, Tim Witt released a modified Coordinate widget that also shows current map scale.  I took the scale-related elements of that widget and added them to the Esri Coordinate widget released with WAB Developer Edition 1.3.
Here's a screenshot of the widget working in an app made using WAB Dev 1.3:
To install, unzip and place "Coordinate" folder in the widget folder of your WAB Dev 1.3 app after deleting the stock Esri Coordinate widget:
WABdev_1.3\server\apps\#\widgets
I strongly recommend that you DO NOT replace the stock Esri Coordinate widget in the base widget folder (\WABdev_1.3\client\stemapp\widgets), as doing so will greatly complicate general app handling (e.g. duplicating, creating) and the importing of apps from WAB Dev 1.2.
Update April 1, 2016:  Initial testing suggests that this widget works in WAB Dev 2.0.
Update July 19, 2016:  Initial testing suggests that this widget works in WAB Dev 2.1.
ThomasSpindler1
I am using the Tab Theme.  Your app has same behavior in my browsers.  In Chrome, it looks like your screen shot above.  However, in IE 11:
BarnabyRockwell
Yes, same for me in IE 11.
ThomasSpindler1
The Foldable theme gives me the same outcome as the Tab theme.  Are you still installing it the same way?   In the server/apps/#/widgets folder?
BarnabyRockwell
Which outcome?  The coords/scale overlying the ruler?  Yes, the widget is installed as per first post.
ThomasSpindler1
Yes, when using Web AppBuilder 2.0 and Foldable theme.  Here is a test app:  ArcGIS Web App
BarnabyRockwell
I've never seen that behavior and can't duplicate it.  You could try removing/re-adding the widget and playing around with the scalebar widget also.
RobertScheitlin__GISP
Thomas,
  The fix is simple (not sure how this got messed up though) in the apps config.json you currently have:
  "uri": "widgets/Coordinate/Widget",
  "position": {
  "left": 7,
  "bottom": 5,
  "relativeTo": "map"
  "version": "2.0.1",
  "id": "widgets_Coordinate_Widget_4",
  "keepConfigAfterMapSwithched": false,
  "name": "Coordinate",
  "label": "Coordinate"
Change it to:
  "position": {
  "left": 200,
  "bottom": 5,
  "relativeTo": "map"
  "version": "2.0.1",
BarnabyRockwell
Thank you, Robert!  The "left" is 200 in all my apps, which I presume is the default, and I never changed that setting, or anything else in the app's config.json, for that matter.
"position": {
"left": 200,
"bottom": 20,
"relativeTo": "map"
"positionRelativeTo": "map",
"label": "Coordinate",
"version": "2.0.1",
Note that I imported the app (including Coordinate widget) from WD 1.3, and thus didn't create it from scratch in WD 2.0.
Cheers,
Barnaby
Barnaby,
  I guess I have been misreading this conversation. I thought Thomas was the once having the overlap issue and providing the link to the site showing the issue?
BarnabyRockwell
Robert,
You are correct.  I just checked my config.json to see if my values matched yours.  I mentioned the importing as perhaps Thomas' config.json got messed up if he created a new app from scratch in 2.0.
Cheers,
Barnaby
