Change the color of a header in AT
3074
15
03-11-2019 12:10 PM
LefterisKoumis
I am looking to change the color of the header by directly click on the header and
also if  column is selected through a click on a list of fields..
For the first task I tried css:
.jimu-widget-attributetable .dgrid-header .dgrid-selected {
  background-color: rgb(34, 228, 34)
but it doesn't seem to be working.
LefterisKoumis
So there is no way you can stop event propagation. What is puzzling is that by just clicking the select box the second time for another field, it triggers refresh, even though no filtering is done. I changed my script so no filtering is performed after you click on the select, for the second field, and it still refreshes the map. Why?I just try to understand the mechanics of it.Does it has to do that the select is inside the toolbar? THanks.
RobertScheitlin__GISP
That must be some side effect from how you have your dropdown event wired up. Here is how mine is setup:
    createToolbar: function() {
      var toolbar = new Toolbar({}, html.create("div"))
      this.refreshButton = new Button({
        label: this.nls.refresh,
        showLabel: true,
        iconClass: "esriAttributeTableRefreshImage",
        onClick: lang.hitch(this, this.refresh)
      toolbar.addChild(this.refreshButton);
//Add filter functionality
      this.filterFieldDD = new Select({
        value: "",
        onChange: lang.hitch(this, this.filterFieldChanged),
        intermediateChanges: true
      html.addClass(this.filterFieldDD.domNode, 'filter-field-select');
      toolbar.addChild(this.filterFieldDD);
      this.thetextbox = new TextBox({
        value: "",
        placeHolder: "type in your filter value",
        onChange: lang.hitch(this, this.filterTextChanged),
      html.addClass(this.thetextbox.domNode, 'filter-textbox');
      toolbar.addChild(this.thetextbox);
//End add filter functionallity
    filterFieldChanged: function(field) {
      query('.dgrid-header th').forEach(function(th){
        if(html.hasClass(th, 'field-' + field)){
          html.addClass(th, 'th-selected');
        }else{
          html.removeClass(th, 'th-selected');
      filter_name = field;
    filterTextChanged: function(value) {
      if (value.length >= 3 && filter_name) {
        var partsObj = {
          "expr": "UPPER(" + filter_name + ") LIKE '%" + value.toUpperCase() + "%'",
          "parts": []
        this.setFilterObj(partsObj);
        this.clearSelection(false);
        this.startQuery();
        this.emit('apply-filter', {
          layerInfoId: this.layerInfo.id,
          expr: partsObj.expr
      if(value === ""){
        this.setFilterObj(null);
        this.startQuery();
          expr: null
Oh. Here is how I populate the dropdown.
    queryExecute: function(oFields, recordCounts, exceededLimit, results, nExtent) {
      var data = [];
      var store = null;
      var columns = {};
      if (!this.domNode) {
        return;
      // mixin porperty of field to result.fields
      this.filterFieldDD.innerHTML = '';
      results.fields = this._processExecuteFields(this.layer.fields, oFields);
      results.fields.map(lang.hitch(this, function(fld, indx){
        if(fld.type !== 'esriFieldTypeOID'){
          this.filterFieldDD.options[this.filterFieldDD.options.length] = new Option(fld.alias, fld.name);
So like I said in my previous post, I am not sure about the soundness of your workflow, but here is how to maintain the css rule on the header after a filter refresh. Add lines 2 -10 to the changeToolbarStatus function.
    changeToolbarStatus: function() {
      if(filter_name && filter_name !== ""){
          if(html.hasClass(th, 'field-' + filter_name)){
          }else{
      //selected/all option
Lefteris,
   This is what I am liking now (cleaner UI/UX feel). Filter icon does not get applied till the table is actually filtered and it persists when the table is refreshed.
define([
  'dijit/form/TextBox',
  "dijit/form/Select",
  'dijit/ToolbarSeparator'
], function(
  TextBox,
  Select,
  ToolbarSeparator
      var toolbar = new Toolbar({}, html.create("div"));
        showLabel: true,
//my quick filter additions
      var sep = new ToolbarSeparator();
      toolbar.addChild(sep);
      html.place("<div class='quickFilterLabel'>Quick Filter: </div>", sep.domNode, "after");
        value: "",
        value: "",
      this.clearFilterButton = new Button({
        label: "Clear Filter",
        showLabel: true,
        iconClass: "esriAttributeTableFilterImage",
        onClick: lang.hitch(this, this.clearFilter)
      toolbar.addChild(this.clearFilterButton);
//end my quick filter additions‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
      query('.esriAttributeTableFilterFieldImage').forEach(function(node){
        html.destroy(node);
      if (this.thetextbox.value.length >= 3 && this.filter_name) {
        var header = query('.dgrid-header th.field-' + this.filter_name + '>div')[0];
        var tip = "Filter SQL: " + this._filterObj.expr;
        html.place('<div class="esriAttributeTableFilterFieldImage" role="presentation" title="' + tip + '"></div>',header, "first");
//end my quick filter additons
      if (!this.tableCreated) {
        //dgrid not created, set initial state
        if (this._relatedQuery) {
          //if RELATIONSHIPTABLE mode, show "Show All Records"
          this.showSelectedRecordsMenuItem.set('disabled', false);
          this.showSelectedRecordsMenuItem.set('label', this.nls.showAllRecords);
        } else {
          this.showSelectedRecordsMenuItem.set('disabled', true);
        this.showRelatedRecordsMenuItem.set('disabled', true);
        this.matchingCheckBox.set('disabled', true);
        this.filterMenuItem.set('disabled', true);
        this.toggleColumnsMenuItem.set('disabled', true);
        if (!this.hideExportButton) {
          this.exportCSVMenuItem.set('disabled', true);
        this.zoomButton.set('disabled', true);
        return;
      //now dgid is created
      var selectionRows = this.getSelectedRows();
      if (this.showSelected) {
        //if this.showSelected is true, means we are in selected mode
        //now we need to show "Show All Records"
      } else {
        this.showSelectedRecordsMenuItem.set('label', this.nls.showSelectedRecords);
      if (this.tableCreated && selectionRows && selectionRows.length > 0 &&
        this.layer && this.layer.objectIdField) {
        this.clearSelectionButton.set('disabled', false);
      } else {
        this.clearSelectionButton.set('disabled', true);
//my quick filter additons
      if(this.tableCreated && this._filterObj){
        this.clearFilterButton.set('disabled', false);
      }else{
        this.clearFilterButton.set('disabled', true);
      this.filter_name = field;
      if (value.length >= 3 && this.filter_name) {
        var partsObj = {
          "expr": "UPPER(" + this.filter_name + ") LIKE '%" + value.toUpperCase() + "%'",
          "parts": []
        this.startQuery();
          expr: partsObj.expr
    clearFilter: function() {
      this.thetextbox.set("value", '');
      this.startQuery();
        expr: null
      var data = [];
      var store = null;
      var columns = {};
        return;
.jimu-widget-attributetable .filter-textbox {
  height: 24px;
  line-height: 24px;
  margin: 0 0.3em;
.claro .dijitInputContainer {
  line-height: 20px;
.claro .dijitTextBox .dijitInputInner {
  height: 20px;
  line-height: 20px !important;
.claro .dijitTextBox .dijitPlaceHolder {
  font-size: 12px;
  height: 22px;
.jimu-widget-attributetable .filter-field-select {
  height: 24px;
  line-height: 24px;
  margin: 0 0.3em;
  min-width: 120px;
.esriAttributeTableFilterFieldImage{
  background-image: url("../images/filter.png");
  width: 13px;
  height: 13px;
  float: left;
  margin: 1px 9px 0 5px;
.quickFilterLabel {
  display:inline-block;
  margin: 0 2px 0 5px;
  line-height: 22px;
LefterisKoumis
Robert, I'd like to thank you for your time and effort to assist me with this effort.
I finally realized why the map kept refreshing when I was clicking on the column header at first, then at the select drop down. Because of  stupidity, I didn't realized that by initializing the textbox,  every time I was selecting another field, I was re-initiating the query of the fields.
this.thetextbox.set("value", "")
What I should have done is that I could keep this line but also use
Anyway, your code is very helpful to understand, among other things, of how to change the default stylesheetsof WAB widgets for a target element.
