Change color of tooltip in WAB
3401
12
11-22-2018 10:36 AM
joerodmey
Have a tooltip that works well. Just having some trouble to effectively change the text color. Code can be found below
// create node for the tooltip
          var tip = "Click on problem location";
          var tooltip = dojo.create("div", { "class": "tooltip", "innerHTML": tip }, map.container);
          dojo.style(tooltip, "position", "fixed");
          // update the tooltip as the mouse moves over the map
          dojo.connect(map, "onMouseMove", function(evt) {
            var px, py;
            if (evt.clientX || evt.pageY) {
              px = evt.clientX;
              py = evt.clientY;
            } else {
              px = evt.clientX + dojo.body().scrollLeft - dojo.body().clientLeft;
              py = evt.clientY + dojo.body().scrollTop - dojo.body().clientTop;
            // dojo.style(tooltip, "display", "none");
            tooltip.style.display = "none";
            dojo.style(tooltip, { left: (px + 15) + "px", top: (py) + "px" });
            // dojo.style(tooltip, "display", "");
            tooltip.style.display = "";
            // console.log("updated tooltip pos.");
          // hide the tooltip the cursor isn't over the map
          dojo.connect(map, "onMouseOut", function(evt){
RobertScheitlin__GISP
var tooltip = dojo.create("div", { "class": "tooltip", "innerHTML": tip, "style": "color: red; font-size:15px;"}, map.container);
Joe,
  What does your
tooltip
css class look like?
joerodmey
.introjs-tooltip {
  box-sizing: content-box;
  position: absolute;
  visibility: visible;
  padding: 10px;
  background-color: white;
  min-width: 200px;
  max-width: 300px;
  border-radius: 3px;
  box-shadow: 0 1px 10px rgba(0,0,0,.4);
  -webkit-transition: opacity 0.1s ease-out;
     -moz-transition: opacity 0.1s ease-out;
      -ms-transition: opacity 0.1s ease-out;
       -o-transition: opacity 0.1s ease-out;
Joe,
  That is not the css class that is being used. It is only using the “tooltip” css class.
joerodmey
I don't have a css class then
joerodmey
Can I apply a color to this tooltip inline to my code?
Joe,
  Add a css rule called "tooltip" to your app then:
.tooltip {
  color: blue;
joerodmey
How can the css be included inline?
Joe,
  I assume you mean inline style (as css rules can not go inline).
var tooltip = dojo.create("div", { "class": "tooltip", "innerHTML": tip, "style": "color: blue" }, map.container);
joerodmey
Perfect thanks!
Can the same text be bolded and size increased?
