Cannot get PanelManager to load in WAB app
2246
03-20-2020 07:57 AM
JustinBridwell2
I am trying to utilize PanelManager in my WAB widget. My WAB version is very old (1.2). I am trying to add it as follows:
define([
//dojo AMD modules
//dojox AMD modules
//dGrid AMD modules
//dijit AMD modules
//esri AMD modules
//jimu web appbuilder AMD modules
'jimu/BaseWidget',
'jimu/utils',
'jimu/WidgetManager'
'jimu/ PanelManager '
function (
//dojo AMD modules
//dojox AMD modules
//dgrid AMD modules
//dijit AMD modules
//esri AMD modules
BaseWidget,
utils,
WidgetManager
PanelManager
// Code goes her
Notice that there are spaces when I add 'jimu/ PanelManager '. This is exactly the way the documentation has it, but when I try to launch my app, it doesn't load because it is incorrect. When I change it to  'jimu/PanelManager' (with spaces removes it loads, but when I try to create an instance variable (see below), I get the error:  "Uncaught ReferenceError: PanelManager is not defined". What am I doing wrong here?
wm.loadWidget(myWidget);
wm.openWidget(myWidget);
var pm = PanelManager.getInstance();
pm.showPanel(myWidget);
RobertScheitlin__GISP
Justin,
   I just checked an old 1.2 version and I have
'jimu/PanelManager',
And I call it this way
this.pManager = PanelManager.getInstance();
Without any error.
Justin,
   There is No space in there the documentation has a typo.
JustinBridwell2
I eliminated the spaces, but I still got the "Uncaught ReferenceError: PanelManager is not defined" whenever I tried to create an instance of the PanelManager:
Justin,
Without any error.
JustinBridwell2
Aha! I just tried using `this.` That seemed to do the trick.
