Caching issue - webappbuilder
1650
04-07-2020 08:39 AM
KafilBaig
When I change the widget.html or widget.js of any custom widget. There is no change in the application unless and until I clear the browser cache. Is anyone facing the same issue . Please let me know .
RobertScheitlin__GISP
Kafil,
  What is the path of the widget.js/.html file that you are editing?
KafilBaig
https://myservername.org/myapplicationname/widgets/ebind/widget.js
I am directly editing in the my application widget folder.
On Tue, Apr 7, 2020 at 9:31 PM Robert Scheitlin, GISP <[email protected]>
Nope, I have not seen that issue before then.
KafilBaig
I added a input button and javascript function in widget.js and saved it. Now when i try to see the changes in my application hosted on IIS it is not taking the new changes unless i go n clear the cache.
i tried to add the below code in jimu.js/widgetmanager.js as per one of the thread https://community.esri.com/thread/158241
var myHostName = "maps.simcoe.ca"
var uid = Math.floor(Date.now() / 100000)
if (window.location.hostname.toLowerCase() != myHostName)
var d = new Date();
uid = d.getFullYear().toString() + "-" + (d.getMonth() + 1).toString() + "-" + d.getDate().toString()
this.preventCacheParameter = "?preventCache=" + uid;
Let me know what is the best solution or workaround i can implement to get rid of this issue.
Thanks In Advance.
