I am currently using WAB 2.10 and have added a Geoprocessing Widget to buffer in previous versions. However, now when I add a new Buffer geoprocessing Widget I dont have the option to use user defined fields?
Solved! Go to Solution.
I took my feature class of 225 poly lines, did a split by attributes, added all the 225 separated FC and published my buffer result as a geoprocessing service, that worked.
George,
So this is something that you are seeing changed only in 2.10? It worked in 2.9?
I can try and look into this but you are better off contacting tech support.
thank You Robert, i will contact tech support, i am thinking that because the feature class is on SDE it might be restricted
