Automatic sorting of the Attribute Table
2294
02-17-2018 10:07 AM
ZdeněkSoldán
Hello,
is it possible to automatic sort values in the Attribute Table after the Table is shown in the app? What I need is to see rows with error attribute automatic on the first places.
Thanks a lot
Regards
Zdenek
RobertScheitlin__GISP
Zdenek,
In the [install dir]\server\apps\[app#]\widgets\AttributeTable\table\_featureTable.js @ line 1811 there is this code:
      if (this.layer.objectIdField) {
        this.grid.set('sort', this.layer.objectIdField, false);
that automatically sorts by object id you could replace that code with your field name.
Zdenek,
ZdeněkSoldán
Robert,
thank you a lot!
One additional question...if I want this sorting only for one layer and for all others sorting by objectIdField?
I tried add else if condition with the original code below changed if condition but it wasn't obviously good aproach.
Zednek,
   You have access to the this.layer so you can determine if it is the layer you want or not. So using an if else if absolutely the correct path.
ZdeněkSoldán
Robert,
it looks good now. Thank you again.
