Attribute Table - Columns width
1033
07-27-2017 07:00 AM
FlorianCADOZ
Hi everyone,
I've got a problem with the columns' width in the attribute table widget of the web appbuilder for developers.
I'm using the LaunchPad theme so my Attribute Table is taking a lot of place (from the bottom to 1/3 of the page), mostly when the elements in the column are longer than the column width, the lines becomes highters and the Attribute Table is starting to be unusable.
So that's why, right now, I'm searching for a method, a property or something else allowing me to custom the attribute table for :
- Detecting automaticaly the field length and using this value for setting the columns width
- Fixing the lines'height
Florian
Tags (1)
