AreaMeasurement3DViewModel - how to make the orange-white checkerboard invisible?
1671
10-17-2023 03:01 AM
MichaelLev
I develop 3D web apps by web appBuilder using ArcGIS API forJAvascript 4.24
AreaMeasurement3DViewModel draws orange-white checkerboard on the screen which "covers" the 3D scene details. This is giving helpful info, but I wish that I can leave the area and perimeter details in the widget while controlling the checkerboard visibility, to be able to set no visibility.
Help from some expert will be greatly appreciated.
MichaelLev
I solved it.
But it's complicated... so I'll describe only generally:
I create a polygon (in graphic layer attached to ground) whose points are identical to the area measured. I label the polygon with the relevant info, then I erase the view model.
My customized "measurements-wizard" widget can display concurrently many measurements ot 3 types: distance (with slope), area, and volume (which is "extended" area neasurement).
The user can replace the orange/white chess board of an area or volume measurement by bare polygons, (whose internals are transparent) labeled with the relevant info.
MichaelLev
I solved it.
