AGOL Webmap as JSON?
3193
12-16-2016 01:55 PM
by Anonymous User
Not applicable
Just curious if there is an "out of the box" way to get the web map as JSON from the current AGOL webmap from within a custom widget?  Unfortunately, due to client specifications I cannot conform to the Export Web Map Task parameters for the GP Service I'll be using.
I know with the JavaScript API, I can use the PrintTask to do the work for me to get the map in the current state by doing this:
var printTask = new PrintTask()
var Web_Map_as_JSON = printTask._getPrintDefinition(this.map))
However, when I try that from a custom widget passing in the AGOL web map, I get the following error:
Another thing I found that will give me the web map is to use the ArcGIS Utils:
utils.getItem(this.map.itemId)
That does give me the web map as JSON, but obviously it is not the current state (i.e. doesn't show which layers are on/off in the current map).  Is there an "easy" way or do I have to manually build it?
RobertScheitlin__GISP
Caleb,
   The problem with using private functions is that they are undocumented. The method takes a map as the first param and a PrintParameters as the second and because you were not providing the PrintParameters.
              var printTask = new PrintTask("your url");
              var template = new PrintTemplate();
              template.preserveScale = false;
              var params = new PrintParameters();
              params.map = this.map;
              params.template = template;
              var Web_Map_as_JSON = JSON.stringify(printTask._getPrintDefinition(this.map, params));
              console.info(Web_Map_as_JSON);
Caleb,
by Anonymous User
Not applicable
Thanks, Robert!  That did the trick.
