Add more Layer Toggle buttons to Launchpad Theme
1952
02-14-2017 09:18 AM
CCWeedcontrol
Add more Layer Toggle buttons to Launchpad Theme. Currently you can only use 3 button widgets at the top of the Launch pad theme. I would like to add up to 3 to 6 more. Can this be done? anyone willing to help more do this please?
Thanks.
RobertScheitlin__GISP
CCWeedcontrol
I followed the instructions per the thread but after making the changes when i use WAB to launch/edit the app i just get the loading turning icon the app never opens.  I went into the config.json and add the three new placeholders there. Under "widgetsOnScreen" object and its "widgets" array like so.
        "uri": "widgets/Splash/Widget",
        "visible": false,
        "position": {
          "relativeTo": "browser"
        "version": "2.3",
        "id": "widgets_Splash_Widget_46",
        "name": "Splash"
        "position": {
          "right": 100,
          "top": 20,
          "relativeTo": "map"
        "placeholderIndex": 1,
        "id": "_47"
        "position": {
          "right": 150,
          "top": 20,
          "relativeTo": "map"
        "placeholderIndex": 2,
        "id": "_48"
        "position": {
          "right": 200,
          "top": 20,
          "relativeTo": "map"
        "placeholderIndex": 3,
        "id": "_49"
        "position": {
          "right": 100,
          "top": 40,
          "relativeTo": "map"
        "placeholderIndex": 4,
        "id": "_47"
        "position": {
          "right": 150,
          "top": 40,
          "relativeTo": "map"
        "placeholderIndex": 5,
        "id": "_48"
        "position": {
          "right": 200,
          "top": 40,
          "relativeTo": "map"
        "placeholderIndex": 6,
        "id": "_49"
        "uri": "widgets/ExtentNavigate/Widget",
        "visible": false,
        "position": {
          "top": 255,
          "left": 25,
          "relativeTo": "map"
        "version": "2.3",
        "id": "widgets_ExtentNavigate_Widget_50",
        "name": "ExtentNavigate"
CCWeedcontrol
Never mind i got it, I forgot to change the "id": "_49" to 50, 51,52.
Thanks for the fast reply and help!
