Add external libraries in WAB Portal version
702
08-19-2020 12:43 PM
TyroneLigon1
I'm using WAB DE to develop a custom widget. I added jQuery 3.5.1 and jQuery UI 1.12 to the webappviewer/libs/jquery folder, and I reference the libraries as such in my widget:
define(
   'jimu/loaderplugins/jquery-loader!libs/jquery/jquery-3.5.1.min, libs/jquery/jquery-ui.min.js'
function (..., $)
Works just fine. Copied the widget folder to our server instance of WAB into webappviewer/widgets, and copied the jQuery libraries into webappviewer/libs/jquery. Registered the widget in the portal as an application extension, created a web app, added the custom widget to the app, launched the app, then opened the widget.
I get a 404 error when the widget tries to load the jQuery libraries, although the displayed path in the browser console matches the physical library location.
Do I have to add the libraries to the init.js resource array?
