Add even more widgets...
589
03-30-2017 04:51 PM
GregRieck
I'm running WAB 2.2 with the Jewelry Box Theme. I have an edit widget and three custom widgets that appear in the WAB widget tab. I need to be able to add more widgets than the three custom widgets I already have. I can add a widget to the header control. However, I do not want the widget on the header control. My intention is to activate the widget via a Feature Action by selecting a feature on the map. How can I add more widgets?
Greg
RobertScheitlin__GISP
Greg,
If you are talking about adding additional on screen widgets to the theme then all you have to do is add them to the main config.json:
  "widgetOnScreen": {
    "widgets": [
        "uri": "themes/JewelryBoxTheme/widgets/HeaderController/Widget",
        "position": {
          "left": 0,
          "top": 0,
          "right": 0,
          "height": 40,
          "relativeTo": "browser"
        "version": "2.4",
        "id": "themes_JewelryBoxTheme_widgets_HeaderController_Widget_19",
        "icon": "themes/JewelryBoxTheme/widgets/HeaderController/images/icon.png?wab_dv=2.1",
        "name": "HeaderController"
        "position": {
          "left": 55,
          "top": 45,
          "relativeTo": "map",
          "width": 200
        "placeholderIndex": 1,
        "id": "_23",
        "uri": "",
        "version": "2.4",
        "closeable": true
        "position": {
          "left": 105,
          "top": 45,
          "relativeTo": "map"
        "placeholderIndex": 2,
        "id": "_24",
        "version": "2.4",
        "closeable": true,
        "uri": ""
        "position": {
          "left": 155,
          "top": 45,
          "relativeTo": "map"
        "placeholderIndex": 3,
        "id": "_25"
        "position": {
          "left": 205,
          "top": 45,
          "relativeTo": "map"
        "placeholderIndex": 4,
        "id": "_26"
        "position": {
          "left": 255,
          "top": 45,
          "relativeTo": "map"
        "placeholderIndex": 5,
        "id": "_27"
        "position": {
          "left": 305,
          "top": 45,
          "relativeTo": "map"
        "placeholderIndex": 6,
        "id": "_28"
Greg,
  "widgetOnScreen": {
    "widgets": [
        "position": {
          "left": 0,
          "top": 0,
          "right": 0,
          "height": 40,
        "version": "2.4",
        "position": {
          "left": 55,
          "top": 45,
          "width": 200
        "id": "_23",
        "uri": "",
        "version": "2.4",
        "closeable": true
        "position": {
          "left": 105,
          "top": 45,
          "relativeTo": "map"
        "id": "_24",
        "version": "2.4",
        "closeable": true,
        "uri": ""
        "position": {
          "left": 155,
          "top": 45,
          "relativeTo": "map"
        "id": "_25"
        "position": {
          "left": 205,
          "top": 45,
          "relativeTo": "map"
        "id": "_26"
        "position": {
          "left": 255,
          "top": 45,
          "relativeTo": "map"
        "id": "_27"
        "position": {
          "left": 305,
          "top": 45,
          "relativeTo": "map"
        "id": "_28"
GregRieck
Thank You Robert, that worked. I did have some duplicate id's, I'm not sure if that matters. It is working and I do see the additional widgets now.
Greg
