Hi Robert .
I am trying to add your eSearch custom widget to the Developer Edition of the Web AppBuilder 2.1 .
Whenever I run the eSearch Widget, I can't add a search layer .It is blocked .
Solved! Go to Solution.
Hi Robert ,
please how to reduce the zoom scale . I change the value but there is no changes .
Amal.
That zoom scale is only used when the geometry does not have an extent (i.e points) If the geometry has an extent than the extent is used, unless you check the "Force Scale" option right next to the Zoom Scale. The Force Scale option will force the use of the zoom scale for all geometry types.
