Add eSearch Widget for WAB
7958
32
10-11-2016 04:36 AM
amalhorchi1
Hi Robert .
I am trying to add your eSearch custom widget to the Developer Edition of the Web AppBuilder 2.1 .
Whenever I run the eSearch Widget, I can't add a search layer .It is blocked .
amalhorchi1
define({
resultactions: "Résultat Menu",
clearResults: "Effacer les résultats",
selectFeatures: "Par Forme",
selectByAttribute: "Par Attribut",
results: "Résultats",
searchLayer: "Couche de recherche",
searchType: "Alias de la recherche",
selectFeaturesBy: "Sélection d\'entités par",
selectSpatial: "Sélection Spatiale",
search: "Rechercher",
clear: "Vider",
clearfields: "Vider les champs",
clearBuffer: "Supprimer la zone tampon",
zoomall: "Zoom tous",
point: "Point",
line: "Ligne",
polyline: "Polyligne",
freehandPolyline: "Polyligne libre",
triangle: "Triangle",
extent: "Etendue",
circle: "Cercle",
ellipse: "Ellipse",
polygon: "Polygone",
freehandPolygon: "Polygone libre",
featuresSelected: "Entités sélectionnées: ",
noResults: "Pas de résultats",
searching: "Recherche...",
searchError: "La recherche a échouée !",
searchResult: "Résultat de la recherche",
useMultiGraphics: "Autoriser les graphiques multi-parties",
addTolerance: "Ajouter un tolrérance à la recherche autour du point sélectionné",
and: "et",
friendlyDatePattern: "MM/dd/aaaa",
stringOperatorIs: "stringOperatorIs",
stringOperatorIsNot: "stringOperatorIsNot",
stringOperatorStartsWith: "stringOperatorStartsWith",
stringOperatorEndsWith: "stringOperatorEndsWith",
stringOperatorContains: "stringOperatorContains",
stringOperatorDoesNotContain: "stringOperatorDoesNotContain",
stringOperatorIsBlank: "stringOperatorIsBlank",
stringOperatorIsNotBlank: "stringOperatorIsNotBlank",
dateOperatorIsOn: "dateOperatorIsOn",
dateOperatorIsNotOn: "dateOperatorIsNotOn",
dateOperatorIsBefore: "dateOperatorIsBefore",
dateOperatorIsAfter: "dateOperatorIsAfter",
dateOperatorDays: "dateOperatorDays",
dateOperatorWeeks: "dateOperatorWeeks",
dateOperatorMonths: "dateOperatorMonths",
dateOperatorInTheLast: "dateOperatorInTheLast",
dateOperatorNotInTheLast: "dateOperatorNotInTheLast",
dateOperatorIsBetween: "dateOperatorIsBetween",
dateOperatorIsNotBetween: "dateOperatorIsNotBetween",
dateOperatorIsBlank: "dateOperatorIsBlank",
dateOperatorIsNotBlank: "dateOperatorIsNotBlank",
numberOperatorIs: "numberOperatorIs",
numberOperatorIsNot: "numberOperatorIsNot",
numberOperatorIsAtLeast: "numberOperatorIsAtLeast",
numberOperatorIsLessThan: "numberOperatorIsLessThan",
numberOperatorIsAtMost: "numberOperatorIsAtMost",
numberOperatorIsGreaterThan: "numberOperatorIsGreaterThan",
numberOperatorIsBetween: "numberOperatorIsBetween",
numberOperatorIsNotBetween: "numberOperatorIsNotBetween",
numberOperatorIsBlank: "numberOperatorIsBlank",
numberOperatorIsNotBlank: "numberOperatorIsNotBlank",
bufferGraphic: "Zone tampon - graphique",
searchDistance: "Appliquer une distance de recherche:",
applyBuffer: "Ajouter la zone tampon",
searchEntities: "Rechercher les entités dans :",
intersectMessage: "Il n\'y a pas de résultats pour l\'intersection, veuillez réaliser une recherche graphique ou sémenatique en premier.",
spatialSearchErrorTitle: "Erreur dans la recherche spatiale",
bufferMessage: "Il n\'a pas de résultat dans la zone tampon, merci de faire une recherche par attributs ou graphiques.",
bufferSearchErrorTitle: "Erreur pour la zone tampon",
spatialchoicemsg: "Souhaitez vous utiliser la zone tampon -graphique ou les Graphiques de sélection ?",
spatialchoicetitle: "Sélectionner",
buffergraphics: "Zone tampon",
selectiongraphics: "Sélection",
widgetversion: "Info. sur la version du Widget eSearch",
widgetverstr: "Widget Version",
wabversionmsg: "Ce Widget a été créé pour fonctionner avec la version du Web AppBuilder",
exporturl: "URL de la Recherche Export",
copyurlprompt: "Copier dans le presse-papiers: Ctrl+C, Entrer",
limit2mapextent: "Limiter les résultats aux cartes mesure",
graphicgeomtypemsg1: "Mélanger les types de géométrie majeurs comme des points, des lignes et des polygones est pas pris en charge.",
graphicgeomtypemsg2: "Voulez-vous continuer ce qui se traduira en effaçant tous les graphiques dessinés précédentes?",
cancel: "annuler",
continue: "continuer",
warning: "Attention!",
zoomErrorMessage: "Les tentatives de zoom automatique aux résultats de la recherche ont échoué.",
addTextQuery: "Inclure le texte requête dans les critères de sélection",
uniqueValues: "Récupération des valeurs uniques",
processingUnique: "Traitement des valeurs uniques: ",
of: " de ",
requiredTip: "Valeur nécessaire pour exécuter la recherche",
required: "Nécessaire",
requiredWarning: "Valeur Obligatoire manquant",
requiredErrorMessage: "Vous avez échoué à entrer un ou plusieurs valeurs requises",
selectFeaturesFrom: "Utilisez des graphiques à partir de",
eLocateTip: "L\'utilisation actuelle Enhanced Localiser Graphics Widget",
createnewselection: "Créer de nouveaux résultats",
addtoselection: "Ajouter aux résultats actuels",
removefromselection: "Retirer de résultats actuels",
mapServiceFailureTitle: "Recherche d\'erreurs couche Map Service",
mapServicefailureMsg: "La couche de recherche suivant (s) service de carte (s) n\'a pas répondu: ",
mapServicefailureMsg2: ". En raison de cet échec la couche (s) de recherche sera supprimé de le widget.",
removeResultMsg: "Supprimer le résultat",
chooserelate: "Choisissez le Relate",
sum_: "Résumé",
summaryresults: "Résumé des résultats",
more: "Plus",
_featureAction_eShowStatistics: "Statistiques...",
_featureAction_eExportToCSV: "Exporter vers un fichier CSV",
_featureAction_eShowRelate: "Afficher Concerne"
RobertScheitlin__GISP
Amal,
and now D:\arcggis-web-appbuilder-2.1\WebAppBuilderForArcGIS\server\apps\18\widgets\eSearch\settings\nls\fr\strings.js
amalhorchi1
define({
settings: "Paramètres",
addSearch: "Ajouter une couche de recherche",
updateSearch: "Mise à jour de la couche de recherche",
addBuffer: "Ajouter des valeurs par défaut à la zone tampon",
updateBuffer: "Mise à jour des valeurs par défaut à la zone tampon",
addSearchExpr: "Ajouter une expression",
updateSearchExpr: "Mise à jour de l\'expression",
addExpressionValue: "Ajouter une valeur à l\'expression",
updateExpressionValue: "Mise à jour de la valeur de l\'expression",
addExpression: "Ajouter une expression",
addLink: "Ajouter un lien",
updateLink: "Mise à jour du lien",
searchTitle: "Titre de la recherche",
expressionsTitle: "Expression(s) de recherche",
linksTitle: "Lien(s) depuis la recherche",
bufferUnitTitle: "Unité de la zone tampon",
spatialRelationshipTitle: "Relation(s) spatiale(s)",
linkAlias: "Alias du lien",
disablenulllink: "Désactivé le lien si Nul",
disablelinkinpopup: "Désactivé le lien dans la PopUp",
popuplinktype: "Lien de type",
linktext: "Texte",
linkimage: "Image",
linkiconcontent: "Icône du lien vers les contenus",
linkcontent: "Lien vers les contenus",
linkiconcontenthint: "L’icône du lien vers le contenu peut être du texte, des champs attributaires, ou une combinaison des deux, qui permet de créer un chemin URL \\ valide vers l’image de l’icône des liens. Pour ajouter des champs attributaires cliquer sur le bouton plus bleu sur la droite de la zone de saisie.",
linkcontenthint: "L’icône du lien vers le contenu peut être du texte, des champs attributaires, ou une combinaison des deux, qui permet de créer un chemin URL \\ valide vers les contenus liés . Pour ajouter des champs attributaires cliquer sur le bouton plus bleu sur la droite de la zone de saisie.",
valuesTitle: "Valeur(s) de l\'expression de recherche",
actions: "Actions",
zoomScale: "Echelle du Zoom",
back: "Retour",
sum: "Résumer cela valeurs des champs",
sumlabel: "somme Étiquette",
searchUrl: "URL de recherche",
browse: "Naviguer",
title: "Titre",
definitionexpr: "Expression de définiton",
expression: "Expression",
searchLabel: "Nom de la Recherche",
searchHint: "Indice pour la rechcerche",
availableFields: "Champs disponibles",
alias: "Alias",
includedFields: "Champs inclus",
cancel: "Annuler",
ok: "OK",
addSearch2: "Ajouter une recherche",
operationalLayerTip: "Ajouter les résultats dans une couche opérationnelle",
initialView: "Vue de départ",
disableTabs: "Modifier Tab Désactivé",
editDefaultSym: "Modifier les symboles par défaut pour la recherche",
editDefaultBuffer: "Modifier les propriétés par défaut de la zone tampon",
editDefaultGraphical: "Modifier graphiques d\'options de recherche",
point: "Symbole ponctuel par défaut",
line: "Symbole linéaire par défaut",
poly: "Symbole par défaut pour les polygones",
includeall: "Tout inclure",
include: "Inclus",
useMultiGraphics: "Autoriser les graphiques mulit-parties par défaut",
addTolerance: "Ajouter, par défaut, une tolérance de recherche à la sélection par point",
keepGraphicalEnabled: "Conserver les outils de recherche graphique après chaque dessin",
autoZoom: "Zoom auto sur les résultats de la recherhce",
pointTolerance: "Tolérance à ajouter à une recherche par graphique de type point",
searchExpressions: "Expressions de recherche",
expressionAlias: "Alias des l\'expression",
addValue: "Ajouter une valeur à l\'expression",
valuePrompt: "Demande",
valueSQL: "Requête SQL",
valueDefault: "Valeur par défaut",
textSearchHint: "Info rechcerche (Exemple de Valeur)",
none: "Aucun",
string: "Chaîne",
number: "Nombre",
date: "Date",
stringOperatorIn: "dans", // e.g. <stringFieldName> in ('California', 'Arizona')
stringOperatorIs: "est", // e.g. <stringFieldName> is 'California'
stringOperatorIsNot: "n\'est pas",
stringOperatorStartsWith: "commence par",
stringOperatorEndsWith: "finit par",
stringOperatorContains: "contient",
stringOperatorDoesNotContain: "ne contient pas",
stringOperatorIsBlank: "est vide",
stringOperatorIsNotBlank: "n\'est pas vide",
dateOperatorIsOn: "est le", // e.g. <dateFieldName> is on '1/1/2012'
dateOperatorIsNotOn: "n\'est pas le",
dateOperatorIsBefore: "est avant",
dateOperatorIsAfter: "est après",
dateOperatorDays: "jours",
dateOperatorWeeks: "semaines", // e.g. <dateFieldName> is the last 4 weeks
dateOperatorMonths: "mois",
dateOperatorInTheLast: "dans le dernier",
dateOperatorNotInTheLast: "n\'est pas dans le dernier",
dateOperatorIsBetween: "est entre",
dateOperatorIsNotBetween: "n\'est pas entre",
dateOperatorIsBlank: "est vide",
dateOperatorIsNotBlank: "n\'est pas vide",
numberOperatorIn: "dans", // e.g. <stringFieldName> in (1000,2000)
numberOperatorIs: "est", // e.g. <numberFieldName> is 1000
numberOperatorIsNot: "n\'est pas",
numberOperatorIsAtLeast: "est au moins égale à",
numberOperatorIsLessThan: "est inférieur à",
numberOperatorIsAtMost: "est au plus de",
numberOperatorIsGreaterThan: "est supérieur à",
numberOperatorIsBetween: "est entre",
numberOperatorIsNotBetween: "n\'est pas entre",
numberOperatorIsBlank: "est vide",
numberOperatorIsNotBlank: "n\'est pas vide",
valueField: "Champ",
valueOperation: "Opération",
valueMethod: "Méthode",
all: "Tout",
any: "N\'importe quelle valeur",
value: "Valeur",
field: "Champ",
unique: "Unique",
and: "et",
operator: "Opérateur",
valueTooltip: "Entrer une valeur",
fieldTooltip: "Choisir dans un champ existant",
uniqueValueTooltip: "Choisir une valeur unique dans le champ sélectionné",
friendlyDatePattern: "MM/dd/yyyy",
askForValues: "Besoin d\'une valeur",
prompt: "Prompt",
hint: "Suggestion",
strMatchMsgPart1: "Obtenir des entités de la couche qui correspondent à ",
strMatchMsgPart2: " A partir de cela et des critères précédents de l\'expression",
userListMsg: "Demander une valeur depuis une liste de valeurs prédéfinies",
predefinedValue: "Valeur(s) prédéfinie",
predefinedLabel: "Étiquette(s) prédéfinie",
list: "Liste:",
addListValue: "Ajouter une liste de valeurs",
predefinedTooltip: "Choisir dans la liste de valeurs prédéfinies",
predefined: "Prédéfini",
error: {
invalidParams: "Paramètres invalides.",
invalidUrl: "URL invalide.",
noFilterFields: "La couche n\'a pas de champ qui peut être utiliser comme filtre.",
invalidSQL: "Expression SQL invalide.",
cantParseSQL: "Analyse impossible de la requête SQL."
edit: "Edition du format du champ",
dateformat: "Format de date",
dayShortMonthYear: "Jour Mois Année",
longDate: "Date longue",
longMonthDayYear: "Mois long Jour Année",
longMonthYear: "Mois long Année",
shortDate: "Date courte",
shortDateLongTime: "Jour court Heure Longue",
shortDateLongTime24: "Jour court Heure Longue 24",
shortDateShortTime: "Jour court Heure Courte",
shortDateShortTime24: "Jour court Heure Courte 24",
shortMonthYear: "Mois court Année",
year: "Année",
custom: "Personnalisé",
useutc: "Format UTC",
currencyfield: "Champ monétaire",
currencySymbol: "Symbole monétaire",
examplecurrency: "€",
precision: "Précision",
exampleprecision: ".",
usethousandssep: "Utilser un séparateur de milliers",
examplethousands: ",",
overrideSQL: "Override",
editBufferUnit: "Ajouter ou Supprimer les unités de la zone tampon",
defaultBufferValue: "Valeur par défaut de la zone tampon",
defaultBufferWKID: "Réf. spatiale par défaut de la zone tampon, WKID",
bufferSymbol: "Symbole de la zone tampon (cliquer pour modifier)",
addbufferunit: "Sélectionner les unités de la zone tampon",
addspatalrelationships: "Sélectionner la ou les relation(s) spatiale(s) disponible(s)",
addUnit: "Ajouter\\Supprimer les Unités",
addRemove: "Ajouter\\Supprimer",
warning: "Aucune unité sélectionnée pour la zone tampon",
addSymbol: "Ajouter une couche de symbologie spécifique",
pointSymbol: "Symbole pontuel: ",
lineSymbol: "Symbole Linéaire: ",
polySymbol: "Symbole polygone: ",
symbologyTooltip: "Cliquer sur le symbole que vous souhaitez modifier.",
spatialSearchLayer: "Couche de recherche spatiale",
editDefaultSpatial: "Modifier les propriétés de recherche spatiale",
layerSymbology: "Symboles des couches",
symbolServer: "Depuis le serveur",
symbolConfig: "Depuis la config défaut",
symbolLayer: "de couche",
requiredfield: "champ obligatoire",
isempty: "est vide",
showinattributetable: "Ouvrez dans Attribute Table Widget Automatiquement",
showattachments: "Afficher les pièces jointes",
andor: "et\\ou",
tobeenabled: "oit activé",
graphicalSearchOptions: "Graphical Search Options",
addgraphicalsearchoptions: "Choisissez Disponible graphique Option de recherche",
editdisabledtaboptions: "Choisissez Recherche Tab(s) pour Désactiver",
graphictab: "Recherche Graphique Tab",
attributetab: "attribut Rechercher Tab",
spatialtab: "Recherche spatiale Tab",
resultstab: "Résultats Tab",
availabletabs: "Désactivé Tab(s)",
popuponly: "Popup seulement",
graphicInteract: "Affichage contextuel sur la recherche de la souris sur graphique",
limit2mapextent: "Activer résultats de limites pour cartographier mesure par les défaut",
addbuffertolegend: "Ajouter la couche tampon à la légende de cartes",
enableExportSearchURL: "Activer URL de la Recherche Export",
of: " de ",
showResultsPopup: "Affichage contextuel lorsque les résultats fiche cliqué",
resultItemSorting: "Tri de l\'élément de résultat",
configureFieldsTip: "Configurez les champs en fonction desquels le résultat de la requête sera trié.",
addNew: "Ajouter une requête",
sortingOrder: "",
ascending: "Croissant",
descending: "Décroissant",
sortBy: "Trier par",
thenBy: "Puis par",
sortDisabledMsg: "Handicapés: couche de service doit soutenir possibilités d\'interrogation avancée: OrderBy",
editSortBy: "Modifier Trier par",
showuseMultiGraphics: "Afficher activer l\'option multi-parties graphiques",
showaddTolerance: "Afficher Ajouter tolérance de recherche à l\'option de sélection du collimateur",
showaddsqltext: "Afficher inclure du texte requête dans option critères de sélection",
showbuffergraphic: "Afficher les options Tampon graphiques",
buffergraphicbydefault: "Activer tampon graphique par défaut",
expressionValueRequired: "Valeur doit être saisi pour permettre la recherche",
enableelocateselect: "Graphics Widget eLocate",
defExprPlaceholder: "En option (voir widgets aider pour plus de détails)",
zoomscaletip: "Échelle de zoom sera applicable à tous les types de géométrie, et pas seulement des points",
forceScale: "force de l\'échelle",
editResultFormat: "Modifier Résultat Formating",
fromatTooltip: "Le formtting réglée ici affectera la popups de résultat et le résultat du widget texte",
attribTitleLbl: "Résultat Attribut Titre:",
attribTitleExample: "prénom",
attribValueLbl: "Résultat valeur d\'attribut:",
attribValueExample: "John Doe",
color: "Couleur",
insertbold: "Audacieux",
insertitalic: "Italique",
insertunderline: "Souligner",
preview: "Format Aperçu",
maxBufferValue: "La distance maximale de la mémoire tampon",
disablePopups: "Désactiver résultats de la recherche contextuelle",
disableUVCache: "Désactiver la mise en cache des valeurs uniques (voir widgets aide pour plus de détails)",
resultWrap: "Wrap texte de résultat",
resultDefaultMsg: "Par défaut est tout le texte pour chaque attribut et son titre apparaît sur une seule ligne et vous permet de faire défiler pour voir texte long.",
usePopupFrom: "Utilisez Popup de",
popupWebmap: "Carte Web",
popupeSearch: "eSearch",
usePopupFrom2: "pour cette couche",
popupWebmapTip: "Si la couche ne pas un popup défini dans la carte du web, alors la fenêtre contextuelle eSearch standard sera utilisé",
dropdownfilter: "Filtre dropdowns utilisant",
contains: "Contient",
begins: "Commence par",
allowcsvexport: "CSV Exporter",
allowgeoexport: "GeoJSON Exporter",
allowfcexport: "Feature Collection Exporter",
startdateminus: "Date de début est la date actuelle moins",
days: "journées",
statistics: "Exclure des statistiques"
Amal,
   Can you edit the
and change this line:
to
forceScale: "force de léchelle",
and start the app again and see if that resolves the issue?
amalhorchi1
Hi Robert ,
Thanks . It's a great widget ! There is no issue . I'am so happy that is will help me in my web application .
amalhorchi1
Hi Robet ,
I'm sorry but just another issue while adding an expression  . How can i resolve it please ?
Amal,
   For some reason the escape character \ is not working for you. So you need to search and replace the \' characters with a blank or nothing in your D:\arcggis-web-appbuilder-2.1\WebAppBuilderForArcGIS\server\apps\18\widgets\eSearch\settings\nls\fr\strings.js
amalhorchi1
Hi Robert ,
Thank you so much. I'm so happy . It is a great widget .
Amal,
   Glad you like it. Sorry about the difficulty getting it to work with the french language.
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
amalhorchi1
Thanks another time . I do mark it as "Correct Answer " .
