Add custom message if feature search fails
893
08-21-2017 02:30 PM
BPriyaK
Hi, Im novice GIS Technicain working with webapp builder for ArcGIS Online.
I have a hosted feature layer of address for search and set up a district lookup wizard to locate the boundary the address fall in.However,If the user types an address not found in the address points feature layer  the message displays-No results found.
I'm curious to know if there is way to add a custom message saying "contact or email this person/phone ".
Is there a widget that can do this.
Any help will be greatly appreciated
Thanks
Bhanu
RobertScheitlin__GISP
Bhanu,
   Because you are using the AGOL Version you do not have any ability to customize, so the answer is no. If you were to create your app using WAB Developer edition (which would mean you have to host your app on your own web server), then the answer would be yes.
Bhanu,
BPriyaK
Thank you Robert !!
Your reply makes sense , using WAB for web maps sounds like a great idea ,but I'm not there just yet !!
