Add a button in WAB that opens a webpage or URL?
5337
06-16-2016 12:24 PM
JohnHarney
Is there a way to add a button (similar to a widget button or icon) to WAB (Developer Edition) that will simply open a webpage or URL?
RobertScheitlin__GISP
LeoLadefian5
You could configure the about widget with a url inside of it?  That would be a workaround.
TimDine
I wasn't able to get a button that sat in the widget bar to do what you're describing.  I wanted to open a help document from there rather than the links bar or the about page.  I built a widget that on it's open event opened a new window with the url I wanted, then the widget panel closed itself.  You can occasionally see it momentarily if you're watching for it, but it give the behaviour I was looking for.
onOpen: function() {
        window.open(this.config.hyperlink);
        var theWidgetID = this.id;
        require(["jimu/PanelManager"], function(PanelManager) {
            console.log(theWidgetID);
            var pm = PanelManager.getInstance();
            PanelManager.getInstance().closePanel(theWidgetID + "_panel");
All,
  I have created a widget for this now:
Url Button Widget Version 2.1 - 07/29/2016
JohnHarney
Thanks Robert. That's exactly what we were looking for!
John,
  Don't forget to mark this thread as answered by clicking on the "correct answer" link on the reply that answered your question.
