Activate contextual window for some layers only
4423
7
01-19-2016 03:13 AM
FlorianCADOZ
Hello everyone !
I would like to create a popup (with the infoTemplate) for some of my layers created through ArcGISDynamicMapServiceLayer.
I'm creating a loop that looks like this :
array.forEach(this.config.operationalLayers, function (layer, i) {
     var template = new InfoTemplate("Attributs", "${*}");
     var dynamicLayer = new ArcGISDynamicMapServiceLayer(layer.url, {
          "opacity": layer.opacity,
          "visible": layer.visible,
          "id": layer.name,
          "infoTemplate": template
     this.map.addLayer(dynamicLayer);
}, this);
The problem is that I want to create some personnalized template for some layers but not all and I don't know if an ifclause in the infoTemplate is usable...
I don't know if is it clear but I don't know how to explain it clearly...
Thank you by advance for helping me !
FlorianCADOZ
Woh... I really didn't understood your code but I found my solution ! (forget to answer to my own post, sorry)
That was really stupid, just a syntax error with the .setInfoTemplates ...
The solution I used :
_loadLayers: function () {
          var popeupe = null, bob = ["*"];
          switch (layer.name) {
               case "Densité de population":
                    popeupe = {
                         0: { infoTemplate: new InfoTemplate(layer.name, "Population : ${ind_c}")}
                    break;
               default:
                    console.log("Défaut");
               "id": layer.name
          dynamicLayer.setInfoTemplates(popeupe);
     }, this);
Sorry to have wasted your time Robert !
RobertScheitlin__GISP
Florian,
   Based on my understanding of your question. Can you not just check the layer name in your forEach loop and if it is a certain match then create your personalized template?
FlorianCADOZ
Yeah that's I'm doing right now but my problem is also that in my app, if I want to have the popup, I need to check the "Activate the context window" in the layerList widget...
I would have the popup defined without checking this fonction for each layers in my UI...
Florain,
   So you are saying that you have to click the "Enable Pop-up" of each layer and that is what are wanting to avoid?
FlorianCADOZ
yes, it's exactly that !
A strange behavior in my point of view...
Florian,
   There is actually quite a bit involved in this... In your widget you need to require
'jimu/LayerInfos/LayerInfos' and its var LayerInfos
Then in the startup function:
startup: function() {
        this.inherited(arguments);
        if (this.map.itemId) {
          LayerInfos.getInstance(this.map, this.map.itemInfo)
            .then(lang.hitch(this, function(operLayerInfos) {
              this.operLayerInfos = operLayerInfos;
        } else {
          var itemInfo = this._obtainMapLayers();
          LayerInfos.getInstance(this.map, itemInfo)
      _obtainMapLayers: function() {
        // summary:
        //    obtain basemap layers and operational layers if the map is not webmap.
        var basemapLayers = [],
          operLayers = [];
        // emulate a webmapItemInfo.
        var retObj = {
          itemData: {
            baseMap: {
              baseMapLayers: []
            operationalLayers: []
        array.forEach(this.map.graphicsLayerIds, function(layerId) {
          var layer = this.map.getLayer(layerId);
          if (layer.isOperationalLayer) {
            operLayers.push({
              layerObject: layer,
              title: layer.label || layer.title || layer.name || layer.id || " ",
              id: layer.id || " "
        }, this);
        array.forEach(this.map.layerIds, function(layerId) {
            operLayers.push({
              layerObject: layer,
              id: layer.id || " "
          } else {
            basemapLayers.push({
              layerObject: layer,
              id: layer.id || " "
        }, this);
        retObj.itemData.baseMap.baseMapLayers = basemapLayers;
        retObj.itemData.operationalLayers = operLayers;
        return retObj;
Then you can do this:
this.operLayerInfos.getLayerInfoById('Parcel Data_0').enablePopup();
FlorianCADOZ
                    popeupe = {
                    break;
               default:
               "id": layer.name
     }, this);
Florian,
   Glad you go it worked out I was having a hard time figuring out why it was not just working automatically when you set the info template to the layer (i didn't notice that you were not no doing that step).
