Access a config file from another widget
3943
12
03-10-2017 03:11 PM
LefterisKoumis
I have a situation that widget A needs to access the config file of widget B. Widget A already has its own config file. I need to compare a field between the two configs from widget A js file. Possible? Thanks.
LefterisKoumis
Perfect. Thank you.
LefterisKoumis
Robert,
Can I perform some map operations (like set a new extent) in the linked js file, if I add the the BaseWidget module? I added it but it still can't recognize the map object.
define(['dojo/_base/declare',
  'jimu/BaseWidget','dojo/Evented',
  'dojo/on',
  'dojo/_base/lang',
  'dojo/_base/html',
  'esri/request',
  'esri/tasks/query',
  'esri/tasks/QueryTask',
  'esri/tasks/FeatureSet',
  'dojo/keys',
  'dojo/date/locale'
  function (declare, BaseWidget, Evented, on, lang, html, esriRequest, Query, QueryTask, FeatureSet, keys, locale) {
    return declare([BaseWidget,Evented], {
   myfunction: function(){
    alert(this.map.id)
RobertScheitlin__GISP
I normally just pass the Widget object into the other module so you have access to all the widgets objects like map.
