Access a config file from another widget
3951
12
03-10-2017 03:11 PM
LefterisKoumis
I have a situation that widget A needs to access the config file of widget B. Widget A already has its own config file. I need to compare a field between the two configs from widget A js file. Possible? Thanks.
RobertScheitlin__GISP
You can get it from the appConfig like this (this is the best way if the widget has yet to be loaded):
this.appConfig.widgetOnScreen.widgets[8].config
Lefteris,
  Inside a widget you can use this.appConfig to get the main config.json. Or you can use widgetmanager to getthe the other widget object and use the widget object like widgetB.config.
LefterisKoumis
Thank you. I haven't used the widget manager for a while and forgot about it.
LefterisKoumis
Similar to this question, to access, for an example, a function from another module, can I use this setup without using the widgetmanager?  If I can, do I call the function correctly? Thanks.
Module A:
define(["dojo/_base/declare",
        "./ModuleB",
    function (declare,
        ModuleB,
        return declare([BaseWidget, _WidgetsInTemplateMixin], {
        startup: function () {
            ModuleB.loadSavedSessionsFromFile();
Lefteris,
   What you have above is not using WidgetManager at all..? If you use widget manager then you can get a reference to the actual widget object and then call a function inside that widget. There are many threads on using WidgetManager to get a widget object back.
LefterisKoumis
I need to revise my question. I am trying to reach a function that is in another js file (not part of a widget). I'd like to have an external js where a large number of functions will be hosted and any function can be easily called by the js of the widget.
As the script shows, one widget accessing a local js. Sorry, I was not clear.
        "./localjs",
    function (declare,
        localjs,
            localjs.loadSavedSessionsFromFile();
Lefteris,
   I don't see anything wrong with that pattern of coding if the local.js is coded as a module.
define(['dojo/_base/declare',
  'dojo/Evented',
  'dojo/on',
  'dojo/_base/lang',
  'dojo/_base/html',
  'esri/request',
  'esri/tasks/query',
  'esri/tasks/QueryTask',
  'esri/tasks/FeatureSet',
  'dojo/keys',
  'dojo/date/locale'
  function (declare, Evented, on, lang, html, esriRequest, Query, QueryTask, FeatureSet, keys, locale) {
    return declare([Evented], {
LefterisKoumis
Somehow it does not work...It should be simple enough.
Widget A
define(['dojo/_base/declare', './test', 'jimu/BaseWidget'],
function(declare, test, BaseWidget) {
  //To create a widget, you need to derive from BaseWidget.
  return declare([BaseWidget], {
    // DemoWidget code goes here
    //please note that this property is be set by the framework when widget is loaded.
    //templateString: template,
    baseClass: 'jimu-widget-demo',
    postCreate: function() {
      this.inherited(arguments);
      console.log('postCreate');
    startup: function() {
      this.mapIdNode.innerHTML = 'map id:' + this.map.id;
      test.myfunction();
      //myfunction();
test.js
  'dojo/Evented',
  'dojo/on',
  'dojo/_base/lang',
  'dojo/_base/html',
  'esri/request',
  'esri/tasks/query',
  'dojo/keys',
  'dojo/date/locale'
   myfunction: function(){
    alert("Can you see me now?")
Lefteris,
   you need to us the new keyword:
var x = new test();
x.myfunction();
