On-Demand GPS Provisioning Widget Thingy: Step 3
1549
05-19-2016 08:32 AM
ThomasColson
1 2 1,549
In On-Demand GPS Provisioning Widget Thingy: Step 2  we created a model to execute the python created in On-Demand GPS Provisioning Widget Thingy: Step 1 . Now we need to publish it as a Geoprocessing Service.
In the Results tab, right-click on the model results and select Share as Geoprocessing Service.
This blog post won't cover how to publish a service, but for this particular GPX tool, there are some settings to pay attention to.
Set the Execution Mode to Asynchronous and Message Level to Info. In my own environment, haven't gotten this to work with any other setting.
Again, to make this easier for folks to use in "Self Service Mode", spend some time on the instructions!
Here's where things go wonky.
The publisher will complain that it can't find an output file referenced in the python. Export the Feature Class to a shapefile using the SAME NAME as you specified in the python, and in the SAME DIRECTORY in the registered data store folder where the SDE connection file is.
Once you've published the tool successfully, you can delete this shapefile out of the  registered data store folder.
On-Demand GPS Provisioning Widget Thingy: Step 4
Tags (3)
2 Comments
RebeccaStrauch__GISP
Thomas...liking this series of posts.  Suggestion, make sure to include a link to the "next step" post at the end of each of the posts.....not just the previous posts at the top.  You may be planning that already, once you have them all posted....but if not...
ThomasColson
Done.
About the Author
This is a personal account and does not reflect the view or policies of my org.
