Water utility network reporting - profiling tool.
4493
11-08-2013 02:39 AM
pabloberlanga_jimenez
Hello!
I'm trying to run the Profiling tool included in the water utility network reporting toolbar v: 10.1
I'm using the example data included in the download.
It doesn't work. I get this error when I try to select the first point (Sewer Manholes):
[ATTACH=CONFIG]28959[/ATTACH]
"object reference not set to an instance of an object"
I didn't edit the config file becouse I'm using the example data.
Thank you in advance!!!
AleydisG__Pere
Make sure you have a Standard or Advanced licence.
I also get that message and it's because I have an ArcGIS for Desktop Basic license.
I'm using a Standard lisence.
[SOLVED]
It is a code error!
Profile tool get the simbology for the selected ponit directly from the map document (ESRI.Styles -> Colors...) and if you have
your installation in other language instead of English, the tool crashes.
MikeMillerGIS
Esri Frequent Contributor
Is this the line causing the issues?
  pMarkerSym = Globals.FindMarkerSym("Esri.style", "Default", "Circle 2", pMxDoc);
