How do I test with my own data  Water utility maps and apps
1554
09-30-2013 11:48 AM
JoseSanchez
Hi all
Is there a way to test with my own data with Water Utility maps and applications. When I hit download it downloads file geodatabases and maps.
http://resources.arcgis.com/en/communities/local-government/01n40000000t000000.htm
MikeMillerGIS
Esri Frequent Contributor
Jose,
   We include a database schema and sample data so you can test drive the tools and maps.  If you want to use your own data, you will need to migrate your data to the data schema or reconfigure the tools to match your data.  You can find some help here.
http://resources.arcgis.com/en/help/localgovernment/10.2/index.html#/Migrating_your_data_to_the_Loca...
JoseSanchez
Michael
What about the Map Notes sample.
http://www.arcgis.com/home/item.html?id=25db16cfe7b64501a0b7f6d132338620#www.arcgis.com/sharing/rest...
How can I test the web application?
