Water Utility Network Editing
4369
06-05-2015 12:42 PM
MarcelaRondon
I just installed the water utility network editing solution add-ins and since i don't have experience coding, i'm having a bit of trouble configuring the tools so they will work with a model that's not the Local Government Information Model. Does anyone have a tutorial i could check out and get started?
ClarePrice1
Not exactly a tutorial, but the Water Utility Network Editing documentation includes pages about configuring the tools to work with other datasets or to perform additional functionality. Modifying the network editing, reporting, and construction tools are outlined.
MarcelaRondon
Thanks Clare, i have the tool documentation in spanish since i first found about the solution for water utilities from the esri españa web, but it's not as clear as i need.  I thought maybe someone could have some "step by step" that shows where i'm supposed to modify the code.... at this rate, if i succeed someday, i'll make it and post it!
