Water Utility Network Editing Tools in ArcGIS Pro and Utility Network
2072
10-03-2024 02:41 PM
shildebrand
Does anyone know if the water geometric network editing and analysis tools have been replicated in ArcGIS Pro for use in a utility network?  In arcmap, we used this tool to automate water lateral creation between a meter location and an adjacent water/sewer main.
RobertThomsonErase
Pretty sure ESRI's utility water network comes with a few templates similar to what you are looking for, see the attached pics of mine
shildebrand
This looks like a group template, which is good for creating multiple features (tee, lateral, hydrant, etc) at once.  What i'm looking for is a way to generate a lateral from a meter to the main for a selected subset of meters.  In other words, if I have 1000 meters, generate 1000 laterals.  This was possible in arcmap with the extension/toolbar I referenced.
GIS_geek
So far I have only found the equivalent of Attribute Assistant, which is Attribute Rules.  I had configured multiple lateral connections using the Add Laterals from Line Locations and have not been able to find the similar tool in Pro.
