Does anyone know if the water geometric network editing and analysis tools have been replicated in ArcGIS Pro for use in a utility network? In arcmap, we used this tool to automate water lateral creation between a meter location and an adjacent water/sewer main.
Pretty sure ESRI's utility water network comes with a few templates similar to what you are looking for, see the attached pics of mine
So far I have only found the equivalent of Attribute Assistant, which is Attribute Rules. I had configured multiple lateral connections using the Add Laterals from Line Locations and have not been able to find the similar tool in Pro.
This looks like a group template, which is good for creating multiple features (tee, lateral, hydrant, etc) at once. What i'm looking for is a way to generate a lateral from a meter to the main for a selected subset of meters. In other words, if I have 1000 meters, generate 1000 laterals. This was possible in arcmap with the extension/toolbar I referenced.
I'm abit late to the party and you may have already come across this @shildebrand but this tool seems to do what you are looking for;
https://www.arcgis.com/home/item.html?id=383363df2b20479695143498bb22997d#overview
