water main segments
4021
11-15-2012 09:01 AM
timsvatos
We have are drawings in AutoCAD files right know and would like to bring the mains, valves and hydrant over to ArcMap 10.1. My question is on the main segments what the best practice of drawing the segments. Our goal is to identify a main with a water main break and it would show us which valves would be shut off.
1. from valve to valve
2. Fitting to fitting
3. Where you have a 3 or a 4-way valve package - would there be like 3 or 4 small segments?
4. Can you go from tee to tee and if you have an inline valve go through the valve or stop the segment at the valve and have two segments.
MikeMillerGIS
Esri Frequent Contributor
Here are some recommandations
    Break Mains at
      All wPressurizedMains intersections
      Fittings
        Cross
        Reducer
        Tee
      System valves
        pressure reducer valves
        pressure (zone) separation valves
        reservoir valves
        system separation (normally closed)
        altitude valves
      Pump stations
      Treatment plant
      Reservoir
    Do NOT break Mains at
      Fittings
        Bend
        Tap
        Wye
        Clamp
      Laterals or lateral services
      Normally open system valves
      Check valves
      Connection points
GrahamW
Hi  Tsvatos
We have chosen to break mains
  • at all fittings
  • valves
  • hydrants (our hydrants are cut in on the mains.. not laterals)
  • Pumps/resevoirs/flowmeters
we don't break for water services.
if i was to re invent the data model I would probably do exactly what MikeMiller is sugesting reasons for
  • Too many assets in our asset system
  • simplicity of data capture
  • doesn't effect modeling requirments
Graham Wood
Water and Sewer GIS Coordinator
Gosford City Council
