Sewer network package
1672
06-17-2025 08:10 AM
ELIZABETH50
I have an asset package, Is it possible to create subnetwork controllers to perform up/down traces in asset packages?
I have created some subnetwork controllers, but only the feature network controller (Directional MH) is selected as the subnetwork.  Any suggestions.
RobertKrisher
I'm not 100% sure what the question is, but I will attempt to answer it.
You can add rows to the C_SubnetworkControllers table in the asset package to define the subnetwork controllers that will be created when you deploy the asset package. If you export a utility network that contains subnetworks to an asset package, this table will be populated with the controllers that were in your utility network.
Tracing requires a utility network, so you won't be able to trace the subnetworks that until you deploy your utility network and resolve your errors.
