Midspan connectivity Utility Network
4557
04-17-2020 12:11 PM
Letíciad_Agosto_Miguel_Fonseca
Hello everyone,
I am trying to configurate my Utility Network to split the water line when I add some device or junction.
Reading this site: Utility Network reference for editing—ArcGIS Pro | Documentation I found that segments should split when midspan connection is not permitted. So I set the edge connectivity to End Vertex for the transmission main asset type, but it is not working.
Am I missing something?
Thanks a lot!
Layane Beatriz Silva Loti
Tags (1)
MikeMillerGIS
Esri Frequent Contributor
I do not believe this is possible.
Thanks for your answer Michael!
We will configurate a template with Split function in our devices.
JavierDistefano
Hi @Letíciad_Agosto_Miguel_Fonseca, I have just the same requirement. Could you solved it? Is there any reference documentation you can share?.
Thanks.
BorisKalimira
Hello,
Did you find a solution to split the water line when you create a valve ?
I'm facing the same problem.
Kind regards,
Simon
StefanStamenković
I also have the same issue, I'd like to be able to ensure splitting line while entering devices on it.
If it is not possible, is there any suggested workaround for same results?
Kind regards, Stefan
